00 Tl
Old Apr 19, 2004 | 09:06 PM
1st timer's Avatar
UB6IB9
00 Tl
Any recalls made on 00 3.2 TL?
Old Apr 19, 2004 | 10:44 PM
fsttyms1's Avatar
http://www.alldata.com/TSB/01/00010926.html
Old Apr 20, 2004 | 12:07 PM
2001TL4KCdude's Avatar
Oracle Apps/Database Dude
this link also takes you to it
http://www-odi.nhtsa.dot.gov/cars/pr.../tsbsearch.cfm
Old Apr 20, 2004 | 12:23 PM
wait, so all the stuff listed there i can change? and since its a recall it's free? do i just go to the dealership and just tell them to change the all of the stuff?
-i have an '00 TL.
Old Apr 20, 2004 | 12:28 PM
fsttyms1's Avatar
ther are only 3 recals those are teh only things to be replaced. the rest are service bullitens of known issues and fixes for the issues (if you have any of them)
TSB Number Issue Date TSB Title 02-010 APR 02 Recall - Passenger Air Bag Replacement
01-030 AUG 01 Recall - Front Seat Belt Buckle Replacement
00-020 JUN 00 Recall - SRS/Seat Belt Indicator ON
General Recalls
TSB Number Issue Date TSB Title 02-027 AUG 03 Campaign - Automatic Transmission Warranty Extension
03-017 MAY 03 Campaign - PCM/Fuel Pressure Regulator Replacement
Service Bulletins
TSB Number Issue Date TSB Title 03-015 AUG 03 Audio System - Remote Controls Don't Work Properly
98-005 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
00-037 JUN 03 Brakes - Brake Rotor Refinishing Guidelines
97-040 MAY 03 Keyless Entry - Description/Identification/Programming
01-017 MAY 03 Brakes - Pedal/Steering Wheel Vibrate When Braking
00-019 APR 03 Antitheft System - Type 2 System Operation/Programming
03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
03-006 MAR 03 Engine Controls - Idle Speed Inspection
03-003 FEB 03 Interior - Power Seat Rail Synchronization Update
03-001 JAN 03 Emissions - MIL ON/DTC P1457 (EVAP) Set
03-002 JAN 03 A/T - MIL ON/No Upshifts/Downshifts/Slipping
02-020 AUG 02 Air Bag System - Occupant Position Sensor Initialization
02-015 JUL 02 Air Bag System - SRS Lamp ON/DTC's Set
02-012 MAY 02 Clutch Master Cylinder - Fluid Leakage
02-006 MAR 02 Front Seat Back Panel - Loose/Detached
02-005 FEB 02 Emissions - EVAP System Testing and Diagnostics
96-025 DEC 01 Navigation System - Component Exchange Program
99-041 NOV 01 Navigation System/A/C - Operation/Testing
01-041 OCT 01 Engine - Oil Leaks
01-016 SEP 01 PCM - MIL ON/DTC P0128 or P1486 Stored
99-051 AUG 01 Exhaust - Muffler Paint Peeling
00-037 AUG 01 Brake Disc - Refinishing Guidelines
01-004 JUL 01 Wipers - Smear or Streak the Windshield
01-011 FEB 01 Radiator/Condenser Fan - Runs Continuously
01-003 JAN 01 Alarm System - Sounds By Itself Intermittently
01-001 JAN 01 PCM/Fuel Pressure Regulator - Hard Starting
00-039 DEC 00 Electrical - Wiring Terminal Replacement Instructions
00-032 NOV 00 Moonroof - Squeaks from Moonroof Seal
00-025 AUG 00 Body - Windshield Molding Deformed
87-015 JUL 00 Audio System - Warranty Non Warranty Exchange/Repair
00-018 JUN 00 Door Switch - Squeaks
00-016 MAY 00 Door Mirror - Vibration
00-015 APR 00 Accessory Moonroof Visor - Creaking Noise
00-014 APR 00 Squeek or Creak From Driver's Seat
00-008 MAR 00 Torque Converter Oil Seal Installation Tool
98-037 FEB 00 Brakes/Traction Control - ABS/TCS Lamp ON/DTC's Set
99-041 FEB 00 TQI OF THE DVD NAVIGATION SYSTEM
00-002 FEB 00 Rear Door Sash Trim is Wrinkled
98-011 NOV 99 Computers/Controls - Aftermarket OBD II Tester/Software
99-040 OCT 99 Troubleshooting DTC P1456 and P1457
99-043 SEP 99 TQI Information (2000 3.2 TL)
96-025 SEP 99 Navigation System Exchange Program
99-033 AUG 99 PDI - Paint Damage From Environmental Fallout
90-007 MAY 99 Steering Wheel Off-Center Adjustment At TQI
98-004 APR 98 Audio Unit Anti-Theft Labels
98-005 APR 98 CV Joint Boots - New Band & Tool
92036 NOV 92 Vehicle Fails State Inspection Emissions Test
Old Apr 20, 2004 | 12:33 PM
so what can i change on my 00? i already did the tranny. anythine else i can get for free?
Old Apr 20, 2004 | 12:39 PM
so from the list i can get:
-pass. air bag replacement
-PCM/Fuel Pressure Regulator Replacement?
what are services issue? i have some (like windshield wipers, Brakes - Pedal/Steering Wheel Vibrate When Braking). do i bring it to them and they do it for free?
- sorry, kinda newbie on these kinds of matter (anything involved w/ money.) wanna make sure i don't get surprised with a bill.
Old Apr 20, 2004 | 12:48 PM
fsttyms1's Avatar
i believe yes on the first 2.
the 2nd is if you are having a problem with the effected (on the list) they have a specific fix for it. meaning, 00-032 NOV 00 Moonroof - Squeaks from Moonroof Seal, if you have this issue (moonroof squeak) they have a fix for it. but i believe you still have to be under warranty for them to fix those with out paying. if you dont have those issues they wont fix them because there is nothing to fix
Old Apr 20, 2004 | 12:57 PM
kewl, thanks.
