Wheel Gap for A Spec
Old Apr 13, 2009 | 06:48 PM
Ravi4l's Avatar
9th Gear
Angry Wheel Gap for A Spec
Hey Guys I just installed A Spec suspension on my 05 RL for some reason gap between all 3 wheels expt RR is same the RR have about 1/2" difference any thought what could be wrong. Thanx again for your help
RK
Old Apr 14, 2009 | 12:30 AM
afjock21's Avatar
2013 RL or bust
I feel your wheel gap pain...
So, you DIY?
Old Apr 14, 2009 | 11:57 AM
Ravi4l's Avatar
9th Gear
i just went thru the acura Install expt did not remove the lower control arm from wheel side i removed from body side that made it bit easy .
Old Apr 14, 2009 | 01:49 PM
afjock21's Avatar
2013 RL or bust
Not sure what you did, but maybe it wasn't a good idea to DIY?
Old Apr 14, 2009 | 02:22 PM
socal28's Avatar
Getting my A-Spec suspension installed through dealer this week. Will let you know how my gaps are afterwards.
Old Apr 14, 2009 | 02:51 PM
Ravi4l's Avatar
9th Gear
it's not about DYI i have install shocks spring on many cars inc porsche BMW honda's but this is the only car i notice the diffrance that could be becouse full gas tank but just checking to see if you guys notice anything
thanks
rk
Old Apr 14, 2009 | 10:51 PM
rtr's Avatar
rtr
RL owner
tire presure?
Old Apr 14, 2009 | 10:58 PM
Chas2's Avatar
How long does it take for the springs to settle?
Old Apr 15, 2009 | 08:00 AM
Ravi4l's Avatar
9th Gear
that;s first thing i check and i took the hight from wheel lip not tire just to be sure, can anyone esle with Aspec check please see what they get.
thanks
rk
Old Apr 20, 2009 | 09:42 PM
Blazing GT's Avatar
may i suggest coils?
Old Apr 21, 2009 | 01:32 PM
Ravi4l's Avatar
9th Gear
I mgiht have to in few months if it doesnot settle down. it might be beasue it;s new
Old Apr 21, 2009 | 02:01 PM
plastikman's Avatar
I had my Aspec suspension installed by the dealer and never had an issue. I don't think it's about settling down, there is something else going on here. I don't mean to be negative, but Acura didn't develop the Aspec suspension kit with a settling down period.
Old Apr 21, 2009 | 03:53 PM
socal28's Avatar
Just got my A-Spec suspension installed by the dealer last week. Thought I'd wait a couple of days for "settling". Just took these measurements on a semi-flat surface (could be ~1% upgrade) and on 1/2 tank of gas. Measured from ground to edge of fender paint (not the black rubber guard).
LF = 27 1/2"
RF = 27 7/8"
LR = 27 3/4"
RR = 27 3/4"
Not sure why my LF is a bit lower than my RF.
Will check again on a different surface later.
I'll try to measure from top of wheel lip to fender later.
Old Apr 21, 2009 | 04:58 PM
socal28's Avatar
Ok, here's my measurement on same sitting from top of wheel lip to bottom of painted fender.
LF = 5 7/8"
RF = 6 1/4"
LR = 5 7/8"
RR = 6"
Overall, I actually can't tell if the A-Spec suspension lowers the height of the car more than regular. I forgot to take measurements prior to the install.
Ride is noticeably more firm. Handling seems to be tighter.
Old Apr 21, 2009 | 05:23 PM
Chas2's Avatar
You need to ride with a few people on the right side for awhile! Compress those springs.
Old Apr 21, 2009 | 05:58 PM
socal28's Avatar
I'm wondering if the Dealer put the wrong set on each side.
Does anyone know if there are labels on the shocks themselves stating left or right side before I take a wheel off to look tonight?
RK, do you recall?
Old Apr 21, 2009 | 08:32 PM
neuronbob's Avatar
There are indeed labels on each coilover to guide the installer. Having pre-install measurements would make helping here a little easier.
Old Apr 23, 2009 | 08:52 PM
Ravi4l's Avatar
9th Gear
For spring it doesn’t say R or L but as for struts for back it’s got R and L on them So I didn’t missup anything there. Man if I know the ride is gona be this hard I would gone with new Stock setup I feel like driving a ricer again.
All 3 wheels got same gap 27 1/8 but the RR got 27 ¾ well hopefully soon I can figure this 1 out.
Thanks a guys.
RK
Old Apr 23, 2009 | 11:00 PM
afjock21's Avatar
2013 RL or bust
I wish A-spec was noticable... It seems like you can BARELY tell the difference when it's installed.... Might have to pair up HR springs with the A-Spec full suspension, and hang onto the A-Spec springs, I guess.....
Old Apr 24, 2009 | 11:45 AM
socal28's Avatar
Noticed a more rigid ride as well. I'm getting used it now though. I actually prefer this ride to the floating kind like stock RL's and most Lexus'.
Initially, my tire pressures were slightly high. I lowered them to what the manual says (32 F and 30 R) it helped a bit.
Yes, hoping it would have been lower. At least to Bimmer sport package level. Oh well.
Old Apr 24, 2009 | 11:47 AM
socal28's Avatar
Oh, and I did check if the shocks were on the right side and they were. Fronts are also labeled with "L" and "R".
Old May 22, 2009 | 06:53 PM
supergreen's Avatar
Is the ride really that harsh with the ASpec suspension?
I have H&R's and have been seriously considering ditching them for an ASpec setup because the ride has become so damn bouncy.... but I really like how low the car sits.
Old May 26, 2009 | 12:56 PM
Ballinger's Avatar
The ride isn't "harsh" but it's less "plush" than the oem/non-aspec suspsension was. I don't find mine to be noticeably lower in stance, but it is more controlled over undulations in the highway at speed and through corners.
Old May 30, 2009 | 12:26 AM
afjock21's Avatar
2013 RL or bust
^ thats what i need
there are times when driving the RL i feel like dammit i need better handling witrh a stiffer ride ie: not floating around the cabin when testing out SH-AWD
Old May 30, 2009 | 07:09 AM
fredren's Avatar
unofficial HONDA rep
so if this is the case, im guessing using the h&r's with the a-spec struts might help with the bouncy ride? i know there are some people with the hybrid setup (a-spec struts with h&r springs)
Old May 30, 2009 | 06:38 PM
hawnr6's Avatar
I have the just H & R's and the ride is definetly not bouncy -- its stiff, but not too stiff.. I have a feeling that the shocks on the other car are worn out, which is causing the bouncy ride..
justin7779
Dec 25, 2015 10:33 PM
DunesCreations
Sep 9, 2015 12:03 PM
nuldabz
Sep 3, 2015 05:49 PM
