installed 2011 RL AC control in 06
Got me an AC control from 2011 RL... Installed it today took ~20min... everything worked flawlessly...
![](http://i170.photobucket.com/albums/u272/psheu/Acura%20RL/2011-07-11193354.jpg)
the 2011 AC control have 2 extra buttons for fan speed and the "Dual climate" button in the older ac control is replaced by the "mode button".... tested out all the function.... everything worked.... straight up plug and play.... and I took apart the AC control.... the 2011 AC control use SMD LED as back light.... while the older one use tiny bulbs
wildwayne (01-12-2012)
Wow... that's cool!
Some questions....
1) So is the Dual function gone with the new unit? I assume Mode works as mode should?
2) How does the color of the LED backlight match the other lights in the Audio and Navi controls that use regular bulbs?
3) Are the temperature controls on both sides backlit with LEDs as well? or just the buttons?
Some questions....
Cruising in ATL!!
Some additional questions:
when you press 'mode' button, does it bring up A/C screen and it goes thru each mode one at a time as you press?
where did you buy the module? junkyard?
How do you now control temp setting individually for driver/passenger now that you got rid of the dual button.
Wow... that's cool!
Some questions....
Some questions....
1) the unit have "Dual" function as default, the mode button will change the vent setup
2) all the color and lighting are the same.... the only difference is that one use SMD LED and the older one use tiny light bulb.
3) everything is the same as the original control. When I took apart the control unit, I compared both the new one and the old one... they all have the same control board (the white part, exactly the same down to the resistors and placement)... the only difference is the front button part (the black part)
RLric2005 (07-14-2020)
I got this unit on ebay for $90 included shipping.... it was stripped from a 2011 RL.
the dual button toggles between fix/dual temperature on driver and passenger side. the new module is always dual for you control temperature via the temp switch on each side or voice control.... in a sense, dual temperature is always there, you don't need a button to toggle it.... I can imagine the original design prob. donno what to put in it's place so they just put DUAL to take up that space. the only thing is that dual button will allow you to line up the temperature to the driver side quickly, if you don't like how the passenger side sets it.
come to think of it, you can just buy the front black part (part with buttons on it) and use the same white part of the temp. control module since they share all the same components.
Some more pictures: (I have LED interior lights so i guess it's bright enough for me not to use a flashlight
![](http://i170.photobucket.com/albums/u272/psheu/Acura%20RL/2011-07-11204847.jpg)
![](http://i170.photobucket.com/albums/u272/psheu/Acura%20RL/2011-07-11204928.jpg)
![](http://i170.photobucket.com/albums/u272/psheu/Acura%20RL/2011-07-11204939.jpg)
picture in total darkness besides the back lite.... I guess all the button lights up even the temp control switch....
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
![](http://i170.photobucket.com/albums/u272/psheu/Acura%20RL/2011-07-11211031.jpg)
it does goes thru each mode one at a time.... and the fan control also.... it also noted the front and rear defrost so you won't press the wrong button ('front' and 'rear' marked clearly on the button)
I assume all of the controls through the "A/C" button for the screen are the same? Also, you missed the question about it pulling up this screen upon hitting "mode". Does it scroll through on the Nav screen or in the background? If it does bring up the screen, can you use the joystick to manipulate it?
Great idea. I would love to do this as I can't stand having to hit A/C to control fan speed. Now we just need someone to put cooling seats in an '08- to prove it can be done.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Can you give us insight into taking the console off, or is that posted elsewhere?
Looks like the part is $207.94 new...
79650-SJA-A11ZA
Kinda steep... but I think I might do it as well... if nothing else, for the LED backlighting to never worry about burnt out bulbs again!
79650-SJA-A11ZA
Q:- Can you give us insight into taking the console off, or is that posted elsewhere?
the console can be taking off easily... first engage ebrake, pull the shifter back, open the 'not an ash tray' lid, now u can pull up the front center console cover (the part that got the seat warmer control), pull the 2 silver trims straight out... up to this point, no tool is required but your hands...
than remove the 4 screws that holds the head unit to the console (you can use socket, or philip screw driver... personally i prefer socket)... pull out the head unit, unplug the AC control plug in the back... remove 4 screws that hold the AC control unit to the head unit...
swap in the new unit, screw, plug, put head unit back, screw, put silver trims back, put front center console cover back... and you r done (the whole thing take <20min doing it carefully)
as for screen, i'm not sure if it pull up the screen cuz our tiny display doesn't have the AC mode on there like the TL (maybe the newer RL's center display have those two additional icons. maybe someone with new RL can shed some light on this)... but it does scrow through all the modes when you push the mode button. the fan speed buttons worked the same way.
Q:- Does the lighting dim properly and still match the other lighting color on the audio and NAV buttons at various levels? Seems strange that the color matches so well between LEDs in that new HVAC unit and regular bulbs in the audio and navi.
well, this is suppose to be the similar unit in the newer model RL so I can imagine they tried to match it as best as they can.... the lighting did dim properly just like the older AC control.
...as for screen, i'm not sure if it pull up the screen cuz our tiny display doesn't have the AC mode on there like the TL (maybe the newer RL's center display have those two additional icons. maybe someone with new RL can shed some light on this)... but it does scrow through all the modes when you push the mode button. the fan speed buttons worked the same way.
As for the screen, I was talking about the Nav screen. When I press the "A/C" button, my Nav changes to a climate control interface. Does it do the same when you press "mode"? Can you press "mode" to pull the screen up and then switch to using the joystick for the settings?
Thanks for the walk through. I knew how on Legend #1, but have yet to get back there on this one.
when you are not on the A/C screen, the mode will still scroll through the changes... you just can't see it:P
No no, i miss understand your question
... the A/C button still work... everything work the same... when you are on the A/C screen, you can scroll through the different modes by pushing the mode button or the jog dial... same with fan speed... everything worked the same... it's just added convenience when u wanna change mode or speed up the fan... and LED back lite![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
psheu (07-12-2011)
[QUOTE=psheu;13084619]just chk the part, it's $194.75 (just the front control part).... when I saw that deal $90 included shipping for the whole unit (black + white part), I jump on it:P
Can you tell us where you looked it up and see it for $194.75??
L, yes.
LOL I think he was asking, if when you press the "mode" or "fan" buttons will the ac screen pop up like it does when you press the "ac" button. Judging by your response, I'm guessing those buttons do not bring you to the "ac" screen. Theyw ill still cycle through regardless if the "ac" screen is up or not. But only the "ac" button wil bring you to that screen
[quote=Megatron;13084938]
you can check www.hondapartsunlimited.com... their price is pretty competitive! my local acura dealer is even more competitive, they'll match any price... if you weight in shipping and tax... local pick up, add tax minus shipping... internet, shipping cost, no tax...
The front control part (buttons )will not fit on the 2005-06 module (board casing), they are different dimension and the screws won´t align.
This lesson cost me $194.75 plus shipping.
I even tried to take out the board from the white casing, but the new buttons don´t work.
I think even the board seems the same the programming is different.
2012 TL SH-AWD
We'll two button don't light anymore on my current setup so need to replace those or maybe it's time to upgrade. Have someone else upgrade to the 2011 ac control yet. You mentioned it's just plug n play so I went ahead and confirm this with parts department and they told me I've to reprogram the AC control. Is this correct.
Oh yeah, on a separate note, I'm thinking of getting the JDM headlights and have a few questions so I'll send you a PM instead.
2012 TL SH-AWD
have it done last night took about 10 min, directly plug n play
but accidentally blown the illuminating fuse took another 10 min to figure it out.
got it from a junk yard from Indiana for 120 +20 shipped the whole unit
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
Soul_Deamon
11-13-2018 04:44 PM
