installed 2011 RL AC control in 06
Got me an AC control from 2011 RL... Installed it today took ~20min... everything worked flawlessly...
http://i170.photobucket.com/albums/u...7-11193354.jpg the 2011 AC control have 2 extra buttons for fan speed and the "Dual climate" button in the older ac control is replaced by the "mode button".... tested out all the function.... everything worked.... straight up plug and play.... and I took apart the AC control.... the 2011 AC control use SMD LED as back light.... while the older one use tiny bulbs:thumbsup: |
Wow... that's cool!
Some questions.... 1) So is the Dual function gone with the new unit? I assume Mode works as mode should? 2) How does the color of the LED backlight match the other lights in the Audio and Navi controls that use regular bulbs? 3) Are the temperature controls on both sides backlit with LEDs as well? or just the buttons? |
Some additional questions:
when you press 'mode' button, does it bring up A/C screen and it goes thru each mode one at a time as you press? where did you buy the module? junkyard? How do you now control temp setting individually for driver/passenger now that you got rid of the dual button. |
Originally Posted by Megatron
(Post 13082814)
Wow... that's cool!
Some questions.... 1) So is the Dual function gone with the new unit? I assume Mode works as mode should? 2) How does the color of the LED backlight match the other lights in the Audio and Navi controls that use regular bulbs? 3) Are the temperature controls on both sides backlit with LEDs as well? or just the buttons? 1) the unit have "Dual" function as default, the mode button will change the vent setup 2) all the color and lighting are the same.... the only difference is that one use SMD LED and the older one use tiny light bulb. 3) everything is the same as the original control. When I took apart the control unit, I compared both the new one and the old one... they all have the same control board (the white part, exactly the same down to the resistors and placement)... the only difference is the front button part (the black part) |
Originally Posted by baboya96
(Post 13082863)
when you press 'mode' button, does it bring up A/C screen and it goes thru each mode one at a time as you press? where did you buy the module? junkyard? How do you now control temp setting individually for driver/passenger now that you got rid of the dual button. I got this unit on ebay for $90 included shipping.... it was stripped from a 2011 RL. the dual button toggles between fix/dual temperature on driver and passenger side. the new module is always dual for you control temperature via the temp switch on each side or voice control.... in a sense, dual temperature is always there, you don't need a button to toggle it.... I can imagine the original design prob. donno what to put in it's place so they just put DUAL to take up that space. the only thing is that dual button will allow you to line up the temperature to the driver side quickly, if you don't like how the passenger side sets it. come to think of it, you can just buy the front black part (part with buttons on it) and use the same white part of the temp. control module since they share all the same components. |
Some more pictures: (I have LED interior lights so i guess it's bright enough for me not to use a flashlight:tongue:)
http://i170.photobucket.com/albums/u...7-11204847.jpg http://i170.photobucket.com/albums/u...7-11204928.jpg http://i170.photobucket.com/albums/u...7-11204939.jpg picture in total darkness besides the back lite.... I guess all the button lights up even the temp control switch.... http://i170.photobucket.com/albums/u...7-11211031.jpg |
Originally Posted by psheu
(Post 13082965)
it does goes thru each mode one at a time.... and the fan control also.... it also noted the front and rear defrost so you won't press the wrong button ('front' and 'rear' marked clearly on the button)
I assume all of the controls through the "A/C" button for the screen are the same? Also, you missed the question about it pulling up this screen upon hitting "mode". Does it scroll through on the Nav screen or in the background? If it does bring up the screen, can you use the joystick to manipulate it?
Great idea. I would love to do this as I can't stand having to hit A/C to control fan speed. Now we just need someone to put cooling seats in an '08- to prove it can be done. :thumbsup: Can you give us insight into taking the console off, or is that posted elsewhere? |
This is something I'd do. How much this part new?
Looks like the part is $207.94 new...
79650-SJA-A11ZA Kinda steep... but I think I might do it as well... if nothing else, for the LED backlighting to never worry about burnt out bulbs again! |
(Post 13084380)
79650-SJA-A11ZA Kinda steep... but I think I might do it as well... if nothing else, for the LED backlighting to never worry about burnt out bulbs again! Q:- Can you give us insight into taking the console off, or is that posted elsewhere? the console can be taking off easily... first engage ebrake, pull the shifter back, open the 'not an ash tray' lid, now u can pull up the front center console cover (the part that got the seat warmer control), pull the 2 silver trims straight out... up to this point, no tool is required but your hands... than remove the 4 screws that holds the head unit to the console (you can use socket, or philip screw driver... personally i prefer socket)... pull out the head unit, unplug the AC control plug in the back... remove 4 screws that hold the AC control unit to the head unit... swap in the new unit, screw, plug, put head unit back, screw, put silver trims back, put front center console cover back... and you r done (the whole thing take <20min doing it carefully):thumbsup: as for screen, i'm not sure if it pull up the screen cuz our tiny display doesn't have the AC mode on there like the TL (maybe the newer RL's center display have those two additional icons. maybe someone with new RL can shed some light on this)... but it does scrow through all the modes when you push the mode button. the fan speed buttons worked the same way. Q:- Does the lighting dim properly and still match the other lighting color on the audio and NAV buttons at various levels? Seems strange that the color matches so well between LEDs in that new HVAC unit and regular bulbs in the audio and navi. well, this is suppose to be the similar unit in the newer model RL so I can imagine they tried to match it as best as they can.... the lighting did dim properly just like the older AC control. |
That's pretty neat. I would totally consider doing that as well.I guess when the bulbs go out and I have to take the unit apart, I would do that conversion.
(Post 13084619)
...as for screen, i'm not sure if it pull up the screen cuz our tiny display doesn't have the AC mode on there like the TL (maybe the newer RL's center display have those two additional icons. maybe someone with new RL can shed some light on this)... but it does scrow through all the modes when you push the mode button. the fan speed buttons worked the same way.
As for the screen, I was talking about the Nav screen. When I press the "A/C" button, my Nav changes to a climate control interface. Does it do the same when you press "mode"? Can you press "mode" to pull the screen up and then switch to using the joystick for the settings? |
Originally Posted by oo7spy
(Post 13084646)
Thanks for the walk through. I knew how on Legend #1, but have yet to get back there on this one.
(Post 13084646)
As for the screen, I was talking about the Nav screen. When I press the "A/C" button, my Nav changes to a climate control interface. Does it do the same when you press "mode"? Can you press "mode" to pull the screen up and then switch to using the joystick for the settings? when you are not on the A/C screen, the mode will still scroll through the changes... you just can't see it:P |
(Post 13084694)
No no, i miss understand your question:tongue:... the A/C button still work... everything work the same... when you are on the A/C screen, you can scroll through the different modes by pushing the mode button or the jog dial... same with fan speed... everything worked the same... it's just added convenience when u wanna change mode or speed up the fan... and LED back lite:tongue:
[QUOTE=psheu;13084619]just chk the part, it's $194.75 (just the front control part).... when I saw that deal $90 included shipping for the whole unit (black + white part), I jump on it:P
Can you tell us where you looked it up and see it for $194.75?? |
L, yes.
Originally Posted by L's TL
(Post 13084930)
LOL I think he was asking, if when you press the "mode" or "fan" buttons will the ac screen pop up like it does when you press the "ac" button. Judging by your response, I'm guessing those buttons do not bring you to the "ac" screen. Theyw ill still cycle through regardless if the "ac" screen is up or not. But only the "ac" button wil bring you to that screen
what he said:thumbsup: The AC control panel doesn't bring up the Navi-screen display. You'll need to hit the A/C button for that to come up.... |
[quote=Megatron;13084938]
(Post 13084619)
The front control part (buttons )will not fit on the 2005-06 module (board casing), they are different dimension and the screws wonīt align.
This lesson cost me $194.75 plus shipping. I even tried to take out the board from the white casing, but the new buttons donīt work. I think even the board seems the same the programming is different. |
That blows, so you need the whole control unit for this to work?
so it was just plug and play?
Originally Posted by DavNyc3
(Post 13405549)
Originally Posted by tguzman
(Post 13393326)
oh ok hopefully i can find a used one so i don't have to buy each individual little bulb and everything this is definitely a nice little mod.
Originally Posted by DeadLock
(Post 13417094)
It is if you buy the entire unit
We'll two button don't light anymore on my current setup so need to replace those or maybe it's time to upgrade. Have someone else upgrade to the 2011 ac control yet. You mentioned it's just plug n play so I went ahead and confirm this with parts department and they told me I've to reprogram the AC control. Is this correct.
Originally Posted by Zelaya
(Post 13456137)
as psheu said, it's plug n play. i did this on my 06 as well.
the only thing i found different is that you would have to get the entire module (front and back pieces). |
(Post 13457545)
nope.... just pull out the old unit and plug in the new unit and it'll work.... no re-program needed.... it's extremely simple, took me <10 min:thumbsup:
Originally Posted by yue3759
(Post 13457992)
the only thing i found different is that you would have to get the entire module (front and back pieces). Hey yue3759, how much did you paid for yours? I'm not having any luck on ebay. |
(Post 13458190)
Thank guys.
Hey yue3759, how much did you paid for yours? I'm not having any luck on ebay. Oh yeah, on a separate note, I'm thinking of getting the JDM headlights and have a few questions so I'll send you a PM instead. |
this is a really cool upgrade!! considering doing it !
so fan speed dont have to adjust from the dial !! |
(Post 13393326)
(Post 13457992)
looks good! I should do that to mine b/c my buttons are wearing off.
have it done last night took about 10 min, directly plug n play
but accidentally blown the illuminating fuse took another 10 min to figure it out. got it from a junk yard from Indiana for 120 +20 shipped the whole unit |
Man, I've been looking for a used one and no luck. Care to share how you found yours.
