XM Traffic stopped working
Old Dec 4, 2008 | 06:53 AM
drolds72's Avatar
Traffic signal just stopped yesterday. The "range" highlight on the scale is gone, as well as the traffic incidents selection. I had XM resend the signal twice with no luck. I am running my backup copy of 4.63, that worked fine for about a month. Everything else on Nav seems to work. Anybody encounter this or have a thought?
Old Dec 4, 2008 | 07:33 AM
CFoote's Avatar
You could try "rebooting" the car by disconnecting the battery for ~10 minutes and then reconnecting. Remember to have your NAV and RADIO anti-theft codes handy.
Chris
Old Dec 4, 2008 | 08:09 AM
Ballinger's Avatar
Wait. Do either of these:
1) Push the Voice Command activation and say, "Display Traffic".
or
2) While in the nav screen, push the big button, then choose "display icons" and then ensure that the traffic icons are set to display.
Both do the same thing. Fair bet this is the glitch. If your car has spirits of the dead children used as ballast in the factory, they sometimes turn off the traffic icons. It's a well-known fact, although often denied.
Old Dec 4, 2008 | 08:29 AM
drolds72's Avatar
The traffic icon, as well as the traffic incidents go from being selectable to grayed out about 15 min into the drive. When the traffic icon is selectable, I make sure it is turned on. Support from XM is practically worthless....
Old Dec 4, 2008 | 10:16 AM
CFoote's Avatar
I'd try the battery reset trick before the dealer (if you haven't already). It sounds strange, but sometimes rebooting the car does indeed solve these gremlins...
Old Dec 4, 2008 | 10:38 AM
drolds72's Avatar
thanks, I will give it a shot tonite and report back.
Old Dec 4, 2008 | 12:20 PM
Ballinger's Avatar
If it works when you're first driving, then goes bad, but works again later when you're "first driving" again, it sounds like an Acura issue rather than an XM problem. It looks like you're getting the signals from XM.
Frustrating, to be sure.
Old Dec 4, 2008 | 04:24 PM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
I had the same issue. Happened twice within 1 week or 2. Each time it was resolved by disconnecting the battery. It hasn't happened again since about 4 weeks.
Old Dec 4, 2008 | 05:18 PM
drolds72's Avatar
To quote someone else in the forum- it was an immaculate repair. Got in car today after work, and Poof! Started working again! I will wait til it happens again and try the battery disconnect. Thanks all for the heads up on that, as I had never even considered it was anything but a satellite problem.
Old Aug 11, 2011 | 11:28 AM
Rob144's Avatar
Nav Traffic Not Working (with icons)
Lately, my NAV Traffic here in Southern California stopped working. The traffic icon is highlighted, but the color-coding doesn't appear on-screen, and there are always "No Traffic Incidents within 30 miles" when I press the Traffic Incident menu.
I called XM, and they sent "refresh messages" to the unit with no affect. They are now saying to bring the car to the dealer because it isn't their issue.
I'm leery of that because after my recent renewal, I had NAV traffic and no radio despite repeated "refreshes". It took several calls to get that resolved, and needed higher level escalation.
Does the battery disconnect really work? I'd also consider (unhappily) a memory wipe from the diag menu.
Rob144
Old Aug 12, 2011 | 06:01 AM
db22's Avatar
Rob144
I too had a very similar manifestation and all along it was XM and their accounting BS. They said I don't have Traffic but I do and the web account shows no traffic subscription but I do. Escalate higher in customer support and rattle some cages. 99% = XM TX, 1% = problem with the RL, I would be very reluctant to reset anything on the RL - it will cause more than it cures with XM issues.
Old Aug 15, 2011 | 11:06 PM
Rob144's Avatar
I agree. The battery disconnect didn't work. I've now spent LOTS of time with customer service. After they converted my subscription to a trial sub until I could go to the dealer, and I did a refresh, it seemed to start working again. Which makes me think the problem is back on their end in the way they set up the subscription. But I'm not sure I trust it anymore. It didn't work when I needed it for my road trip to LA.
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
acurajj
Sep 19, 2015 03:47 PM
PortlandRL
Sep 14, 2015 12:01 PM
ShyGuyMcFly83
ILX
Sep 11, 2015 10:51 PM
theinsvnity
Sep 10, 2015 10:22 PM
