weird start up
Old Jun 27, 2010 | 05:52 PM
cls3's Avatar
weird start up
Everything powers up fine, so I'm pretty sure it's not a battery issue. Car won't turn over, though. There's a rapid clicking sound accompanied by a motley collection of warning lights (oil level, ABS, VSA, etc). Any idea what this problem might mean?
I actually did finally get it to start. Now it acts normal. I'm pretty sure the car didn't fix itself. I feel sure it's going to rear its head again.
Old Jun 28, 2010 | 11:19 AM
SnoWRL's Avatar
maybe the immobilizer acted up hapenned on my 99 maxima once and never again sometimes with all these computers and electronics things go haywire
Old Jun 28, 2010 | 11:51 AM
getakey's Avatar
sure sounds like a battery issue to me
Old Jun 28, 2010 | 12:28 PM
23109VC's Avatar
that sounds exactly like a bad battery. you have enough juice to get the lights going, but when the starter is engaged, it can't make the starter turn over... it just clicks..and then you get all the flicking lights, etc...
that's a bad battery. $5 says you change the battery and your problems are solved..
when you get it working again, you may have to reset presets and maybe yoru windows.. i had a problem like this and my windows in the back wouldn't go down and I had to go through that process to reset them... easy to do..
good luck.
I wouldn't buy it at the stealer..get it at Costco/Sears/etc $50-75 and you're good to go
Old Jun 28, 2010 | 12:31 PM
Chas2's Avatar
Of course, it may still be under warranty. I got a 2006 and they replaced the battery for free
Old Jun 28, 2010 | 12:41 PM
cls3's Avatar
Turns out that it's actually the alternator. The battery is a bit low, but it's because the alternator isn't charging it. That's what I got from the auto parts guy, anyway (after he ran his diagnostic test).
Now I just need to figure out how to replace the alternator.
Old Jul 18, 2010 | 05:11 PM
makumsay's Avatar
Most likely its your battery. mine did the same thing and i replaced it with a red top one. when i took it out, i noticed the fluid level in it was low only after 3 1/2 yrs.
obert
Dec 14, 2015 11:36 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
andysinnh
Sep 5, 2015 11:38 PM
jordanboi
Sep 5, 2015 01:33 AM
