Question on video input to Nav screen
I just ordered a USA Spec PA11-HON2Y for ($129.00) and a DVD player ($190.00)
How do I hook up the video out of from DVD player to the Nav screen?
I looked at the diagram of USA Spec PA11-HON2Y and I do not see anything about the video input.
What do I need to connect to video from DVD player Nav screen?
Any help would be appreciated.
AsianTL
AsianTL
AsianTL
AsianTL
How do I hook up the video out from DVD player to the Nav screen?
What do I need to connect the video from DVD player to Nav screen?
You have to unplug the wires that goes into the nav dvd and plug in the hon2y into the same place.(make sure you have ordered the plug and play verson) There should be a small on off switch that comes with the part. When you flip it on, it should override the nav screen. Of course, you have to find the power wire in the trunk area. Did I tell you that you have to take all the lining out of the trunk? It can be a mess, but the end result is you can watch video on the nav screen. I installed the dvd player on the flip opening between the center rest and the trunk for easy change of dvd. You can chose where to mount it in the trunk or anywhere in the car for your own convenience. Also, you might want to extend the wire of the on off switch. I did that so I can put it under the steering wheel for close access. But its pain in the ass to route the wires.
Thanks for the info.
I am not sure the one I bought is plug & play version.
Please post the picture of your NAV DVD in the trunk with the Y cable or any info. about the Y cable.
I would appreciate your time.
Thanks,
AsianTL
Thanks,
AsianTL
Hi AsianTL, I forgot one very important thing. There should be a third part involve. You have to buy this conversion part from www.tvandnav2go.com The instructions I mension before is for this part. The usa spec is for the dvd sound to come out of your factory radio and ipod. Please PM me if you any question. I'll try to answer them to the best of my ability.
This is what I am talking about the video input.(TVandNav2Go unit)
Thanks again.
also check out the navtogo thread.
I found the thread and really like your set up.
https://acurazine.com/forums/showthread.php?t=4722
Soul_Deamon
11-13-2018 04:44 PM
NewtoAcura11
09-28-2015 04:40 PM
andysinnh
09-05-2015 11:38 PM
