Bluetooth Module Draining Battery
Old Mar 16, 2020 | 01:51 PM
Gerry Zagorski's Avatar
Thanks to some posts here on the same subject, I was able to determine the faulty bluetooth module on my 2006 RL was draining the battery if I didn't use the car every few days... Apparently when the module fails it continues to run and drain your battery even with the ignition off...
Here is a post I found that takes you through the steps of finding and disconnecting it.. In my case, rather than remove the module, I just left it in place and disconnected the green plug to it...
https://sparkys-answers.com/2016/06/...ad-parked.html
Old Mar 7, 2022 | 01:00 PM
HenryW's Avatar
Thanks to your post. i too had to unplug the cables from the module. Good info posted!
BobF4321
ILX Problems & Fixes
Mar 25, 2019 03:22 PM
RenaissanceCar
May 10, 2015 01:54 PM
RDXOXO
Nov 3, 2007 05:37 PM
¿GotJazz?
Jun 22, 2007 11:15 PM
Mike_TX
Oct 4, 2006 06:58 PM
