Transmission fluid drain EMERGENCY
Hey guys,
I'm trying to do a tran fluid drain and refill on my 07 RL. Removed the drain plug but NOTHING is coming out. I thought maybe it was too low so tried pooring in some ATF...NOW the dipstick is showing its WAY above the correct fluid level. Any thoughts? I don't think i have the wrong plug...
Hey guys,
Try to look for it again. If you look specifically for 3/8" square-holed bolts, it should be easy to spot. I would NOT drive it with that tranny overfilled.
So i haven't been driving the car yet since i changed the ATF. I went to check on the fluid level today to see where it was, and saw that it was above the upper mark. This is while the engine was still cold. Before i attempt to fix the fluid level, i just wanted to check to see if this could be correct/incorrect etc. I filled 2.9 US qt according to the 2007 RL service manual. Would the fluid level go down if i let the engine run to operating tempature?
I overfilled mine last time with about 1/8" showing above the mark--engine off but at operating temp. Tech said no damage long term.
To be safe I took it in and had them adjust it--which they did for no cost.
vybzkartel - Are you sure? Because when i overfilled the first time to check what i thought was the drain plug, nothing came out of it. I've been filling through fill hole below the fuse box.
professor - I think that was just the flash from my iphone that made it look gold.
Right now i have it right below the upper mark while at normal operation temp after draining some ATF fluid. Next time I'll try to remember to just check the fluid level as I pour rather than just putting in the exact amount the service manual says.
I just double checked my source. If you put in 2.9q in, you should be fine.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
lanechanger
Oct 13, 2015 10:56 AM
