steps to doing front brake pads...anyone know how?
i want to replace my front pads. 2005 rl has anyone done the front can walk me through steps... i have done pads on audi etc... but would like steps if person done it... thanks for info
Haven't done this yet on my RL, but it should be a easy affair. On 4 piston calipers like ours you don't have to remove the caliper. There are two pins. Remove those and the old pads will come out. Use a piston compressor and then pop in the new pads.
'05 RL 300K Miles
I've done 3 sets in the front. It's kind of funny that the rear brakes are still original. Anyway, it takes about 15 minutes to get the job done.
There's a cotter key in the back of the caliper that needs to be removed, then push the pins out, remove the outside pad, squeeze the inside pad with a couple of big ass pliers to push the piston back in, throw some graphite junk on the new pads install and make sure the holes line up in the pins so you can get the cotter key through, then stick the "V" part of the key in the little hole in the back of the caliper and you're done. Simple.
DON'T buy Green Stuff EBC pads, unless you like TONS of BLACK BRAKE DUST that will cover every square inch of your rims. I'm going back to Honda brakes after this set burn off.
'05 RL 300K Miles
Originally Posted by Touge
FN P90, other than the brake dust how did the ebc green's feel stopping wise vs the oem pads ?.
rockyboy
12-06-2022 02:29 PM
asahrts
09-04-2015 05:55 PM
