Shaky mirror
Old Jun 1, 2007 | 01:19 PM
cwdonahue's Avatar
Angry Shaky mirror
Went to the carwash a few weeks ago and noticed afterward that my driver's side mirror has the shakes. Lumps, bump, etc. cause the mirror to shake. So, it seems to have lost its stability. I tried pushing on the mirror and moving it around a bit. Doesn't seem to have helped much if at all.
So, I'm hoping you all have some suggested fixes, because buying a new left side mirror won't be cheap.
Thanks.
Old Jun 1, 2007 | 02:38 PM
static808's Avatar
I had mine replaced. No questions asked from the dealer. Seems to be a problem. I have an 05 RL.
Old Jun 1, 2007 | 02:41 PM
cwdonahue's Avatar
I guess I won't mention the "car wash" part of the story.....
Old Jun 1, 2007 | 07:22 PM
static808's Avatar
yeah, no need. I tried everything and when my car went in I told the tech to take for a ride on some bumpy roads. Next thing I noticed was a brand new mirror.
Old Jun 1, 2007 | 07:59 PM
mr_allenp's Avatar
I was able to fix mine, there is this snap on cover at the bottom of the mirror which you will have to snap off it's place. There's a slot where you can insert what ever tool you will use to snap it off. Get a masking tape, tape off the part of the door that's near the work area to prevent some accidental scratches. Once the cover beneath the mirror is off, you will see screws that you will just then tighten. If it doesn't work then go to the dealership. I know you would rather have the dealership fix it specially if it's under the warranty, but the wait is what bothered me in the first place that's why i decided to give it a go myself.
Old Jun 1, 2007 | 08:01 PM
mr_allenp's Avatar
And just wondering, why would you bring your car to a car wash. You can buy no rinse car wash products that you can use to wash your car yourself and prevent scratches and broken parts that a car wash can do to your car. Check out the Wash and Wax section and you will see which to buy and how to use them.
Old Jun 1, 2007 | 09:13 PM
medrxman's Avatar
Had the same issue. Was at the dealer and mentioned to service writer and he was about to order a new mirror when the service director came by and showed him the snap cover to show the tech. Viola no more loose mirror.
Good job on your part.
Old Jun 2, 2007 | 01:45 AM
chickenprotein's Avatar
8th Gear
Thanks.
i had same problem with my 2005. when i went took it to the dealer at syracuse they said they cant replace it unless they know all 05's have same problem. a week later this guy called me and said all 05's have loose side mirrors. i guess acura noticed this issue because 06's have different parts number and they did not shake. i took it to motorworld (also NY) they chaged it for me w/o a word. dont go servicing in syracuse acura... they just blow..
Old Jun 3, 2007 | 08:48 AM
bluemule's Avatar
Thanks.
On my '05RL, I stuffed a piece of leather shoe lace into the space between the mirror and holder. Works well.
'05RL with delivery June, '05.
81,000+ miles.
Old Jun 3, 2007 | 10:58 PM
donsnyder's Avatar
donnie
mine were loose. I noticed they would move when taking off at a redlight, or going over pot holes. The dealer replaced both mirrors at no charge.
Old Jun 4, 2007 | 10:03 AM
cwdonahue's Avatar
Thanks for all the replies.....
I'll locate the little snap door and break out the screw driver to give it a try on my own first. It's apparent that something is loose, not really broken.
As for why I would go to a carwash....well...it's called lots of business travel to fill up my weeks and a long list of things to do each weekend. I wish I had the time and enegy to wash my own car, but I don't. Also, I've gone to this same carwash since the day then opened. Never had an issue. If anything goes wrong, the owner makes it right.
Old Jun 16, 2007 | 04:58 PM
FN P90's Avatar
'05 RL 300K Miles
Same problem with mine. You just need a STAR KEY or a Hex KEY WRENCH to tighten a couple bolts, I can't remember which one I used. An Allan wrench won't work.
Old Mar 1, 2008 | 04:26 PM
fafpak's Avatar
What tool to pop off cover?
What tool did either of you use to pop off the plastic cover? I have the same problem but I'm afraid of damaging the cover/door edge. Thanks.
Old Mar 2, 2008 | 02:51 AM
mr_allenp's Avatar
First, be sure to put some masking tape exactly below the snap off under the mirror to be sure you won't scratch the door in case your screw driver slip. You can probably use those small screw drivers used by jewelers, they will fit in the small gap or just about anything you can fit in there. I used a very small allen wrench, as they are angled, it's easier to use leverage in snapping off that cover. Just remember to put some protection on the the door when you go this way.
Old Mar 2, 2008 | 09:19 AM
fafpak's Avatar
....I used a very small allen wrench, as they are angled, it's easier to use leverage in snapping off that cover...
Worked like a charm. Was able to get the cover off. The two screws are bolted down pretty darn tight but there is still some play. I think the only solution is to find a couple of rubber/silicon type washers to eliminate the slack space. Thanks mr_allenp.
Old Mar 2, 2008 | 08:03 PM
bluemule's Avatar
The little short piece of leather shoelace poked down into the space between the mirror and the mount is still working great on mine...very satisfying fix, I might add.
'05 RL delivery date June, 05
111,000+ miles.
ITSJESTER
17
Dec 6, 2018 02:29 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
blacktsxwagon
Oct 27, 2015 10:12 PM
