setting up garage entry with RL
Old Jan 22, 2011 | 08:40 AM
asookazian's Avatar
i tried to set this up in the past with no luck. i followed the instructions in the manual. The garage door opener signal or something (maybe the battery is low?) is weak because it typically takes several tries to open the garage door with the supplied remote.
any tips on this? i got this to work in my old house with my 2000 TL.
i have 2006 RL now.
Old Jan 22, 2011 | 09:20 AM
asookazian's Avatar
Martin DC2500, I checked the online owner's manual PDF and it doesn't seem to support the 2nd part of the instructions in the RL manual (i.e. it doesn't have those specific programmable buttons it talks about in the RL manual).
I tried the 1st part of the instructions and it never flashes quickly...
Old Jan 22, 2011 | 09:21 AM
tnobori1's Avatar
Missing my
You may have a rolling code garage door opener. Try the setup for that and see what happens.
Old Jan 22, 2011 | 09:23 AM
tnobori1's Avatar
Missing my
Did you clear the old codes before you started?
Old Jan 22, 2011 | 11:34 AM
neuronbob's Avatar
Go here:
http://www.homelink.com/program.php
The manual is not quite correct. I had to use the website to set up my RL correctly. If it doesn't work (it may take up to several tries, but it worked on the first try for me), then it's dealer time to rule out a dead module.
Old Jan 23, 2011 | 06:18 PM
HEAVY_RL's Avatar
Go here:
It took me a while to get my set, you have to have patience with the rolling codes.
Also make sure you clear out the codes in there now first.
Old Jan 23, 2011 | 07:59 PM
037's Avatar
037
sometims you have to hold the button for a couple seconds for the doors to open...that was my first and only issue setting up...
Old Jan 23, 2011 | 08:01 PM
thephantom's Avatar
Maybe you need to sync it with the motor base?
Old Jan 23, 2011 | 08:02 PM
HEAVY_RL's Avatar
another good point, and some times more than once.
sorry for the +1ing everything but I also had to extend my antenna wire because the garage was deep.
Sep 17, 2015 09:01 PM
RenoTL
Sep 17, 2015 07:45 PM
P1zzaman
Sep 17, 2015 04:56 PM
CadiGTi
Sep 14, 2015 06:37 PM
braveheart
Sep 7, 2015 08:12 AM
