Setting the clock 2007 RL
Old Jan 5, 2022 | 01:00 PM
Buster Hyman's Avatar
Need help to set the clock - dutifully i followed directions in manual - after entering hour the manual tells me to press the center of the interface knob - however when i press the knob it goes back to incorrect hour - when i don't press the knob it allows me to enter minute when i comple the minute of the hour (last step) the manual tells me to press the center of the interface to enter time - it does not enter the time - it reverts to an incorrect time - any help?
Old Jan 5, 2022 | 02:14 PM
Pair of TLs's Avatar
https://tiremeetsroad.com/2022/01/03...ncorrect-time/
Old Jan 13, 2022 | 09:55 PM
racerock's Avatar
Very nice find.
Our 05 RL clock is an hour ahead and we cannot change the time. I believe the calendar was set to around the date in the link as well.
What is somewhat odd but probably not related we have an 05TL that we cannot change the time. That has been the case since mid 2021.
Old Jan 14, 2022 | 11:28 PM
legebdaryboss's Avatar
Same issue
Originally Posted by racerock
Very nice find.
I’m having the exact same issue for the past few weeks. After I figured out you had to press ‘OK’ on the nav screen to access the clock setting I just couldn’t adjust the clock. It keeps going back to the previous time, which is one hour behind. Any suggestions would be very helpful.
thanks
‘07 RL
Old Jan 15, 2022 | 10:09 PM
You could always disconnect and reconnect the battery at 1:00 ...lotsa peeps doing that.
Old Jan 16, 2022 | 05:04 AM
KB2toKB1FRN's Avatar
Y2k22 honda navi glitch honda states will autocorrect by Aug 2022 let see if this is true
Old Jan 16, 2022 | 02:21 PM
stevieray's Avatar
2007 LSM KB1 Tech w/CMBS
On my 2007 KB1 w/CMBS & ACC, mine was 1 hour off after 1/1/22 but i was able to set the correct time and it hasn't reverted back. I HAD installed the 2018 Navigation update disc so maybe having an upgraded disc does have something to do with it.
Old Feb 16, 2022 | 06:29 PM
Clocks will be reset by Honda in August
I called Accura Corporate - they are very helpful - they are aware of the clock reset problem and will have a fix Aug 22 -
Old Feb 16, 2022 | 08:41 PM
No kidding?
Old Feb 16, 2022 | 11:31 PM
fabioel99's Avatar
Haa, I cant believe that's the cause. I was starting to think about battery issues.
Wooodis
Mar 14, 2014 09:07 AM
Thomasv
Dec 17, 2012 07:49 AM
ImaTLguy
Nov 4, 2005 07:14 PM
kurt
Mar 19, 2004 05:36 AM
shocker
May 23, 2003 03:25 PM
