RV6 AWD RL Long Tube J-Pipe Release!
#243
I got a custom exhaust so I doubt the video will help you guys who have stock exhausts...I'll post it later on but I'll def give you my opinion on the performance
#244
im definitely feeling the mid-range power increase when stepping on the gas... I do notice some slight increases in exhaust noise, but nothing compared to what I was expecting given the other assorted video uploads around.
#246
OK....to me you can't talk about increase in power without a dyno (e.g. objective information). If there is more noise it can SOUND more powerful. Sorry, I'm just a stickler for this when people pull out "seat of the pants" descriptors. Just my and I did this while I owned and modded my RL.
So has anyone done a before and after dyno of this setup? Not that there'd be much change from just a J-pipe, but if there is, someone oughta document it.
#247
Ok so I just got this installed. I have not reset the ECU yet. Only had a chance to drive to the groceries. I also finally got my rear 09 sway installed at the same time. I think I feel more hp (even thought I think anything under 20hp can't really be felt right?) I did floor it to the groceries and back. It started to sprinkle, so I am waiting for it to go away before wasting more gas. I will reset ECU and drive it hard when I get a chance.
#248
Weak! No dyno, just speculation at this point! Although I am glad this is available for us, it's weak, so many people bought and installed and all we get is it sounds good I feel and increase blah blah blah! Post some real results and quit making me waste my time to check this thread!
#249
The point of the J-pipe mod is to make the exhaust tone deeper for those who like a little sport with their lux. That's pretty much it and there is certainly nothing wrong with that. It's really not much of a power adder. If you're not interested in a different exhaust tone, then you are indeed wasting your time. All the reports so far are positive, so it must be meeting the expectations of most.
That said, I'd love to see a dyno to document whether it indeed adds a few hp. If it happens, great, if not, equally great for the reason stated above.
#250
Keep wasting your time bud.
ichi d (04-01-2012)
#252
Where do you get this idea that a j-pipe is not performance oriented? IIRC, your exhaust/intake combo only produced a 12 whp gain. Could you not feel that?
The following 2 users liked this post by oo7spy:
neuronbob (04-01-2012),
SSjTrunks112O (04-02-2012)
#253
Obviously changing part of the exhaust from anything other than stock will increase the tone, however that doesn't mean an increase is their, that said I do believe a less restrictive j pipe will produce results and is the probably the best performance mod for the RL. As for you mr Heavy... No tears here guy, just interested in some numbers as butt dynos have never proven to be reliable!
#254
Ok, so just done resetting ECU and went for a spirited drive. And dammnnnn, either I've been driving like a grandma or I I can feel the difference!! I feel in the mid to upper rpms pull harder. I don't think I have reset my car even after the pulley and intake. But I do love the feeling!! Right after a reset, I noticed a change in tone in the exhaust outside. In the inside, I can't tell a difference. I am liking this mod!! I definitely recommend this. I originally based my purchase off of the TL dyno posted above. I probably will never go dyno my car. I also want to note, I do smell something now with the jpipe installed. Dunno if its because how hard I drove it or because its more free flowing, but the smell is definitely there.
#255
Fatty which method did you use to reset your ECU?
#256
I turn ignition to number 2, stepped on the gas for 30 seconds, while keeping the foot on the gas turned the ignition off and then let go gas. Sat for 2 minutes and I think I heard a click inside the car after about 2 minutes. Then off I went!
The following 2 users liked this post by fatty:
ichi d (04-01-2012),
#257
Thanks for the data, oo7spy. I did say, "not much of a power adder". I guess I stand corrected on that front, and happily so. That much to the wheels should definitely provide a "seat of the pants" effect.
I'd love to see some RL data but expect less at the wheels because of the severe parasitic loss of SH-AWD, which I documented in my multiple dynos.
Rock on, all!
Rock on, all!
#258
I would love to see a dyno or at least 0-60 compare as well, but Richie realizes the difficulties of the SH-AWD on a dyno just as you and Touge did. I think with the 3G TL data we can assume at least 10-11 whp based on a 15% loss in the TL and 30% loss in the RL. With ~220 whp in the RL, you would be looking at a 5% gain.
Is the 3G TL engine 3.2 or 3.5?
#259
Both. The non-S TLs had a J32A3 engine and the Type S had a J35A8.
oo7spy (04-01-2012)
#260
That's what I thought. I know the Dyno above was done on the base, so the 3.5L should gave better gains I would assume.
#262
I believe they were already proven to fit. Do you have an exhaust mods? or are you going with pre cat deletes, jpipe, and stock cat back? Those two mods alone on my Accord's 3.5 yeiled me over 40whp and 40wtq. It was amazing the combo of only those two mods on stock catback
MrKev (04-14-2012)
#263
Let me get this straight.. The 3G tl and 7G accord precats work on the 2G RL?! Where can I found that info? If that's true then thats a hidden gem for sure and coupled with the j pipe should most definatley yield some WHP!
#267
Cool, let us know how it turns out!! I didnt know these fit either! More hp in the low end or high end you think?
#268
Guys this is amazing! I can't wait to hear how the two sound in conjunction with the oem catback which I fully intend to keep! Unless of course the 5zigen becomes readily available! Man we definatley needed these mods to get some of our HP back that the AWD system stole from us, I can't say how excited I am. Anyone know when the next batch of j pipes will be produced? Or a list I can sign up for?
#269
#271
Is there any difference between the high flow pre cats & pre cat deletes besides what's indicated on the RV6 website? Do the HFPC's provide higher whp & wtq gains when combined with the J-Pipe & Oem Catback? Is there any difference in sound or ability to pass an inspection? From what I read, they both seem to fit but the HFPC's are $200 more..
Also, what's up with the "Intended for off road use only" statement on the RV6 website? Does that apply to the ceramic coating only or the product itself?
Thanks in advance..
Thanks in advance..
#272
Thanks in advance..
Thanks in advance..
HFPCs DO provide whp and wtq gains, even paired by themselves. the gains only climb as you free up more parts of the exhaust system (jpipe, and catback)
from what I've heard there is a SLIGHT difference in sound with HFPCs. With PCDs the sound is more noticeable and may create rasp on a non resonated system
I dont think people who do visual or sniffer inspection tests can pass with the PCDs but they should be able to pass with the HFPCs (i think)
The intended for off road use applies to the actual products because it is illegal to change catalytic converters if they are not damaged or to remove them altogether. Its a disclaimer. same as the surgeon general warnings on cigarettes and alcohol
Depending on what state you live in though there is no real risk. For instance I live in Maryland where if there is no CEL I pass emissions inspection. So i can run catless cars through there all day if there is no check engine light.
When I get this raise I'm expecting I'm going to order the PCds or the HFPCs. I'm really leaning towards the HFPCs
SSjTrunks112O (04-12-2012)
#273
Jpipe gives you power in the low end and mid range, while the pre cats provide more power in the high end. But both of these mods provide power throughout the entire powerband. They are the two best mods for any j series engine (for older j series engines headers are)
The difference is the pre cat deletes are just straight pipe with no restriction and the high flow pre cats are 200 cell catalytic converters
#274
No problem.
No codes should appear with the HFPCs, if they do something isnt connected right.
From the reviews I've read and videos I've seen with HFPCs, there is no rasp produced by them. They barely change the sound at all. Just makes it more aggressive.
Lastly, the manufacturer would have to prove that the part is what caused whatever you are trying to get fixed under warranty to fail. Check out the Magnusson-Moss Act. Typically, exhaust mods are overlooked as they really do not alter anything. But with changing the cats I would assume your emissions warranty would be voided. But I'd just chnage them back if you ever had a problem related to emissions (Doubt you would)
SSjTrunks112O (04-13-2012)
#279
Can anyone point me in the direction of those pcds fitting our 2g RL the mod bug has me itching and I'd like to know for sure before I dive in blind, my wheels were enough to get without weds telling me they fit 100%!
