Rubber under tire well separating
Old Jul 15, 2014 | 01:07 PM
Mr.Tea's Avatar
Hello Guys the black lining that runs along the wheel well is peeling at the corners from the metal.
Do you know what kind of adhesive i can use to hold this back in place? I went to auto zone and was told that J-B Weld cold -weld steel reinforced Expoxy would work? Any suggestions would be welcomed.
Old Jul 15, 2014 | 03:35 PM
oo7spy's Avatar
Pics?
Old Jul 15, 2014 | 03:48 PM
253RL's Avatar
Take to body shop. Get expert opinion. The guys at auto zone just want to sell you something. Never use jb weld unless you know what your doing.
Old Jul 15, 2014 | 04:29 PM
BDoggPrelude's Avatar
JB Weld also makes something permanent. If you're talking about the plastic wheel well shields, that's something that may need to be removed for service in the future. I can't think of anything in the wheel well that is rubber or glued into place. The wheel well shields are held in place by screws and clips.
Old Jul 15, 2014 | 04:36 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
^+1 Agreed
OP have you had recent service or any work on the front end near that wheel? Guessing there might be some clips might be missing.
Old Jul 15, 2014 | 04:49 PM
yeah man, pics would be very helpful.
Old Jul 15, 2014 | 05:28 PM
titomang's Avatar
Do you mean the rear wheel wells or the front? The front is held by all clips and the rear is held by clips and adhesive. I'm guessing you probably meant the cloth rear well liner?
If it's peeling, I would clean the back of the it really well and apply some industrial adhesive (preferable 3M)
Old Jul 15, 2014 | 06:59 PM
Mr.Tea's Avatar
I am speaking of the rubber that runs along the wheel well frame...its about 1/2 inch wide strip. Not the cloth panel held by clips under the shock area....
Old Jul 15, 2014 | 07:31 PM
Türk's Avatar
Still no pics?
Old Jul 15, 2014 | 07:36 PM
I just looked at my car and there is no such strip of rubber. Is it possibly an added on fender trim guard?
Old Jul 16, 2014 | 05:44 AM
Mr.Tea's Avatar
http://s1376.photobucket.com/user/grumpygill1/library/
Old Jul 16, 2014 | 05:46 AM
I cant say Ive ever seen that.
but if you want to fix it, apply some adhesive
Old Jul 16, 2014 | 06:26 AM
Sock's Avatar
Mine is doing the same thing on the passenger side.
Found various threads around here that said to completely remove them since they seem to encourage rust... which is in fact the case on mine.
Old Jul 16, 2014 | 07:09 AM
Mr.Tea's Avatar
I recently removed my Mud flaps....since i no longer live up north....is this a good or bad thing. I also think the car looks better without them?
Old Jul 16, 2014 | 08:01 AM
NBP04TL4ME's Avatar
Mud flaps are a personal choice but even in GA they may come in handy from time to time as you do have mud/clay there too - right??
Old Jul 16, 2014 | 09:30 AM
FoxRL's Avatar
You need to take these off.
I live in Canada and come winter when they salt the roads for ice melting, the water/salt combination get wedged between the rubber lining strip and the wheel well lip - this causes the rust process.
You are doing more good by taking it off then leaving it on.
It is a Honda/Acura thing.
Old Jul 16, 2014 | 09:46 AM
projektvertx's Avatar
Mine did the EXACT same thing on both side shortly after I bought the car. I attributed it to the automatic wash I took it thru right after I bought it. I would advise you to avoid JB Weld, as others have said. Remove it and replace it with a strip of XPEL that wraps around that edge.
Honda wanted to avoid rocks chipping the paint there and triggering rust. Problem is it traps moisture. XPEL prevents said rock chips without running the risk of moisture entrapment. In my area, doing XPEL there costs about 50$ in parts and (mostly) labor for both sides.
Old Jul 16, 2014 | 07:07 PM
Mr.Tea's Avatar
where can i find this (XPEL)?
Old Jul 16, 2014 | 07:16 PM
http://locator.xpel.com/clearbra_ins...States/Georgia
Those are the pro-installers in Georgia. I'd assume 3M does the job, but I went with XPEL because they warranty their films longer.
EDIT: The installer should use some bulk film as there is no pre-cut kits for that area.
csmeance
Jan 7, 2026 06:25 PM
cycdaniel
Dec 17, 2019 10:58 AM
forrie
Sep 15, 2015 09:57 AM
BookemDanole
Sep 11, 2015 04:53 PM
bailey24
Aug 31, 2015 05:38 PM
