roof leak
Old Aug 11, 2020 | 02:16 PM
Dallas81's Avatar
6th Gear
roof leak
Has anyone had an issue with a very inconsistent leak at the aline(roof) on the driver's side near the sunvisor? It only happens when it rains EXTREMELY heavy, but not all the time. I had a windshield guy look at it a few years ago, found no leakage. I had the sunroof drained a few times, but nothing was found. Seems like a defect or a body part issue.
Old Aug 11, 2020 | 04:36 PM
have you popped off the a pillar to see if perhaps the sunroof drain is disconnected? I've seen reports of it . Have you had the car the since new or was it used? Perhaps the windshield was replaced in the past and they didn't install it properly
Old Aug 19, 2020 | 02:17 PM
rlx015's Avatar
You may want to check out these links:
https://acurazine.com/forums/second-...photos-876338/
and this one:
https://acurazine.com/forums/second-...n-rust-973654/
I personally had an issue on my RL where windshield was replaced according to the dealer something was not done right - the accuracy of that can be debated until the end of time, but we all know how dealers are... anyhow, bottom line is, there is a leak where it causes rust that is not visible in the beginning... take off windshield pillar and also plastic/rubber strip to dispose and inspect for any rust - that is likely where you will find the leak spot.
I fixed mine with temporary silicone adhesive but again, I have now 210k on my car - debating if I will fix up all rust spots or leave it as is and drive it until it dies
ThermonMermon
Home & Garden
Oct 18, 2018 02:03 PM
gopeman
Jul 23, 2017 10:23 PM
Blazing GT
NY/NJ
Feb 12, 2010 02:48 PM
TypeRS
1G TSX Problems & Fixes
Oct 25, 2006 02:07 PM
hobbestec
Jun 7, 2004 10:35 AM
