2005 RL timing belt
2005 RL timing belt
Greetings, I could use some expertise. I set both cam shafts to the timing marks and the crank shaft to it's timing mark. After replacing the timing belt, when it put the crank pully on, the white mark (single dot) is retarded about 45 degrees vs the mark on the lower cover. Could someone give me some insight? Thanks.
el.profe
02-20-2020 06:26 PM
kaushiknair
05-15-2013 02:44 PM
sajigore
10-13-2008 06:57 PM
