Replacing Differential Fluid
Old Jun 22, 2009 | 08:26 PM
Chulodee's Avatar
Has anyone here replaced the differential fluid? I received a reminder that the fluids should be replaced at 52k miles.
Old Jun 22, 2009 | 08:46 PM
Professor's Avatar
Карты убийцы
I received a MID at 18K then again at 90K. Go figure????
Old Jun 23, 2009 | 05:24 AM
mlts0807's Avatar
'05 RL & '10 MDX
I had it done at 75,000 and then again this past Saturday at 162,000.
Old Jun 23, 2009 | 06:23 AM
robarsan's Avatar
Having it done this morning (B16) service. Currently have 38K miles. They replaced my rear differential not too long ago so I doubt the fluid needs replacing.
Old Jun 23, 2009 | 02:35 PM
sr4dt's Avatar
Needs to clean up
162,000 is yours the highest mileage G2 RL on this board.....
Edit: Did you rackup all those miles in just 4 years ....
Old Jun 23, 2009 | 02:46 PM
sr4dt's Avatar
Needs to clean up
Found another one with 245,000 You guys are on the road a lot...
:iwillstopthreadjackingnow:
Old Jun 23, 2009 | 08:38 PM
mcdillon27's Avatar
Just had my rear differential fluid replaced at 75k + miles today. B16 service light came on. The cost for the differential fluid change was $95 and I had a !0% off coupon which brought the price to $85. I would like to do it myself as I change my own oil etc.... however, you need to have the car jacked up and level.... a lot of work without a lift.
Old Jun 24, 2009 | 08:23 AM
fredren's Avatar
unofficial HONDA rep
i changed my rear differential every 30K and my tranny fluid at every 15K. my odo read 38K as of this week.
Old Jun 24, 2009 | 10:51 AM
drolds72's Avatar
You need a 3 ton jack and a pair of stands. 2.5 ton jack will not work, because it does not lift high enough in rear. Place stands at normal lift points behind front tires, and then level vehicle with jack under center tie down loop just under bumper.
If you do this yourself, you will need 4 new aluminum crush washers, as there are two chambers that hold the fluid. Not much at all. A small fluid pump is key to refilling.
Old Jun 24, 2009 | 01:56 PM
Chulodee's Avatar
$95? I was told $139.99 and $99 for the transmission when i went in to inquire.
Old Jun 24, 2009 | 03:03 PM
JPSMAN's Avatar
Has anyone changed the front differential/transfer case fluid?
Old Jun 24, 2009 | 03:30 PM
drolds72's Avatar
Not yet, but it looks pretty straight forward. There is a drain plug and a fill plug (33 ft lbs) that need to be removed (2 new aluminum sealing washers needed) to change approx .5 quarts of SAE 80w90 hypoid gear oil. (I think that is what my old outboard's lower unit took!)
Old Jun 26, 2009 | 03:40 PM
2007AcuraRL's Avatar
What brand & type of pump did you use?
Old Jun 27, 2009 | 04:51 AM
drolds72's Avatar
just a cheap little hand pump that screws onto the top of the oil container. 7 or 8 bucks at walmart or napa. Looks like the top of a handsoap dispenser with a length of hose on it.
Old Jul 1, 2009 | 06:48 AM
2007-RL-Tech's Avatar
6th Gear
When my RL was 6 months old they topped off the Rear diff fluid. Before that I complained of a slight vibration when accelerating from standing still with moderate or heavy throttle. Topping off the fluid fixed that issue. Thus it's probably worth the $95 to be safe.
Old Jul 1, 2009 | 08:13 AM
fredren's Avatar
just a word of advice to who ever changes the rear differential fluid themselves that make sure you drain and REFILL BOTH chambers with adequate ATF fluid. if not, it'll cost approx $3000. to replace the rear diff on the RL.
Old Jul 1, 2009 | 10:47 AM
drolds72's Avatar
If you don't have the proper jack and stands, it might be worth getting it done, but otherwise its a piece of cake- its not like Acura is going to assign one of their master techs to do this for you!
Old Jul 1, 2009 | 10:52 AM
drolds72's Avatar
Yep, I mentioned that in post 9- be sure to use new crush washers!
Old Jun 1, 2010 | 10:18 PM
shoppit's Avatar
What is the Honda or Acura part numbers for the differential crush washers? Are they the same as the oil bolt crush washers?
Old Jun 1, 2010 | 11:32 PM
Treblig's Avatar
Had mine done at recent B1 service (37K miles).
Old Jun 3, 2010 | 05:40 PM
1HOT NSX's Avatar
This one might help:
https://acurazine.com/forums/2g-rl-2005-2012-76/rear-differential-oil-change-497458/
mada51589
Jan 9, 2025 04:40 PM
cobra10363
Jul 23, 2024 04:13 PM
nanos
Nov 12, 2015 08:41 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
CaliBud916
Sep 19, 2015 01:56 PM
