Rattling noise on acceleration (low rpm)
Old 05-29-2012, 04:30 AM
4th Gear
Schz's Avatar
hi all,
i've recently had an issue which i need help for.. I discovered some days back that when i drive my 05 acura rl,on accelerating especially on high gear on low speed btw 1 & 2 rpm,it makes a cranking/rattling sound and fades away after 2 rpm.
It really has bothered me and i need to know if any1 has experienced such with the acura RL 05 models up..
Thnx
Old 05-29-2012, 05:28 AM
253RL's Avatar
I have a few rattles here and there kinda annoying at times. Just turn the radio up and ignore it! Remember it's a 7 year old car 50k or not it'll develop it's rattles and quirks. If it ain't broke don't fix it!
Old 05-29-2012, 04:06 PM
Matt W's Avatar
Does it sounds anything like a bird chirping. I've recently noticed a bird chirping sound when I accelerate and it's annoying the hell out of me
Old 05-29-2012, 04:12 PM
shahram72's Avatar
Spring has come and went! You would think they would have moved out by now!
Old 05-31-2012, 02:30 AM
4th Gear
Schz's Avatar
i've tried to listen from sounds in d heat shield, and i cant sat. Also,i looked up other forums and saw that it could be the timing belt area or wheel bearings. I dnt know what to do...
Old 05-31-2012, 03:12 AM
253RL's Avatar
I had a weird low pitch hmm and vibrate type noise, it's since disappeared when I installed my pcds, I suspected axle heat shield so I left it off as well as a few other unnecessary heat shields, I also got some extra well needed weight savings and probably gained some real HP from it too!
Old 05-31-2012, 08:41 AM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
OP, we need more info to accurately diagnose. Where does the sound come from? What does the rattle sound like, metal, plastic, or is it possibly an interior rattle?
Old 05-31-2012, 11:24 AM
Matt W's Avatar
This is what my noise is like!:
Originally Posted by Arizacura
I have an 05 with 101,000 miles. The whining or whistling just started about 3000 miles ago. It startsa bout 44 mph after car is warmed up. Continues until I am back down to about 35 mph. It doesnt stop, get louder, or quieter on increasing speeds. Continues in neutral at same speeds. The sound is more like the sound of a loose belt (high pitched whistle), just not rpm related. Unfortunatley, I am not under the class action suit on the odometer increase that would extend warranty to 105k. I have taken it to a local Japanese car Shop for diagnostics, but they couldnt hear it to well. I will take it to dealer for next oil change and get their opinion. I have heard temperature has an effect (below 50) but it occurs on mine at 75 degrees. Any other high mileage RLs? What should I expect. I love the car, not the cost to repair.
Old 05-31-2012, 03:28 PM
4th Gear
Schz's Avatar
mine appears to sound out of the driver's front tire and has a metallic rattling sound. Anything above 2rpm,the sound disappears..
Old 10-19-2012, 08:55 PM
Matt W's Avatar
Now that I have redone my exhaust I am hearing this metallic rattling sound exactaly as the OP has described...I have a feeling it may be the heat shields. Are these heat-shields necessary?
Old 10-19-2012, 10:06 PM
Type S Zero's Avatar
that sound usually comes from the primary or secondary catalytic converter's on a J-series that old driven in winter areas (salt + calcium = rust)
Old 10-19-2012, 10:30 PM
Matt W's Avatar
Thanks for the insight!
So why wasn't I hearing this sound before I had redone my exhaust? Is it because there wasn't as much flow through the converter?
Old 10-20-2012, 12:18 AM
sorry i forgot to write "catalytic converter's heat shields"
Old 10-20-2012, 03:57 PM
Matt W's Avatar
Going to jack my car up and try and see what I can do.
ichi d (10-24-2012)
Old 10-24-2012, 12:44 PM
MDs1's Avatar
I had that. It took me some time to figure out what was causing the noise. It turns out that the driver side brake dust shield edge was the cause of the problem. I pushed the top side edge of the shield away from the rotor and the problem was solved. Give it a try and see if that solves your problem.
ichi d (10-24-2012)
Old 10-24-2012, 04:14 PM
ichi d's Avatar
i will try this when i put on my winters.
Old 11-09-2012, 04:18 PM
scrim67's Avatar
did u ever figure out what that "bird chirping" noise was as I have something similar at higher speeds...
mike
Old 09-04-2014, 04:13 PM
7th Gear
CrossFitter's Avatar
If anyone else is hearing this rattle on low rev acceleration, next time your car is on a lift, tap the exhaust header pipe where they come together....if it rattles upon tap with a hammer what has happened is the baffle welded to the inside of your exhaust manifold has rusted loose.
This is a common issue with both Honda's and Acura's. They add the baffle to provide a "throatier" sound, but they end up falling apart and rattling in the exhaust.
When I looked to see if it was the dust shields on my front rotors or heat shield on catalytic converter, my neighbor who is a mechanic ask what I was doing and "schooled me".
Old 06-30-2015, 06:25 PM
grappler171's Avatar
Crossfitter I think that you are onto something. I also had an issue with that type of noise at lower RPM's. My issue though is on my 2001 Honda civic. Materials from the catalytic converter melted and broke loose and was pushed into my muffler. It creates a rattle inside the muffler that I can hear inside the cabin at low rpm. I had midas take the muffler off and shake out as much of the crap they could and it got rid of most of the noise. They couldn't get it all out though and I didn't want a new muffler cause it wasn't bad at all. Had to replace the cat though .
ExcelerateRep
12-11-2015 12:58 PM
2012wagon
09-29-2015 04:21 PM
iCrap
09-11-2015 06:21 PM
HeloDown
09-08-2015 06:51 PM
Quick Reply: Rattling noise on acceleration (low rpm)
