Quick Question about the RL(2009~2012) Tail light Normal?
The first picture is my Acura RL(09) tail light.
You can see the right side light doesn't turn on.
However, in the second picture, the Right side light turns on.
Which one is normal?
I'm not sure which one is normal status cause I can't compare it with other RLs.
I have never seen the other RL's light on the night in my city.
Originally should be turned on?
The turn signal should be amber 7440NA, but the lide marker lights do not work for you, in order to check them you need to make sure that the voltage comes to the lights, if it passes, then you need to saw the housing and re-solder the faulty LEDs.
If, with the lights on, the taillight lights up, then 12 volts comes through the red wire.
Are you sure those are actually tail lights & not US-spec side marker lights?
It may be that they're not legal (or legally-required) in South Korea. Most Hondas over here in Europe have them deleted - particularly the front (orange) ones which could be confused with turn signals.
Thank you for your many replies.
Honda Legend, the version of Asia, doesn't turn on the light of the left side (Honda Legends KB2).
Only USA version's (Acura RL) turn on the side.
After I realized, for the reason, I replaced my Asian version's tail lights with USA version's tail lights.
Now, It works...!
Thank you guys!
Now, It works...!
Thank you guys!
altair47 (06-02-2022)
Joe Foe from Buffalo
03-24-2021 01:31 PM
