Defective shock or something else?
Old Jun 12, 2022 | 02:24 PM
m8393's Avatar
7th Gear
Hi,
So last fall I did an overhaul of my suspension; replacing struts (sachs) , and upper and lower control arms. Recently I noticed that my driver side shock is badly leaking oil and is totally toast. I've driven probably less than 5k miles since getting the work done. I'm pretty sure that I noticing the suspension feeling off after it was put on a lift and I do think that this caused it (even though Sachs denied that that is likely) , but there is one other thing I'm concerned about.
The reason I replaced the shocks to begin with was that I hit something on the highway while coming home one day. It got kicked out from the car in front of me, it looked like a chunk of metal, but it hit my driver's side wheel. Immediately my tire sidewall and my shock got blown out . I wasn't aware of any other damage, but I decided to replace the control arms just in case. The mechanic that did all the work also didn't notice anything else wrong.
Are there any other things that I should be looking at that may have gotten damaged, or is it likely I just got a dud shock? What do you guys think?
Old Jun 13, 2022 | 04:21 AM
DanL07RL's Avatar
I suspect that if there was other damage from the strike, the dealer would have fallen all over themselves to point it out.
I suspect a dud shock and the dealer should replace it free.....or pick a new mechanic.
DerrickW
17
Feb 26, 2020 08:05 AM
tj19855
Sep 21, 2016 04:51 PM
docboy
Mar 21, 2014 08:38 PM
tomf
Mar 12, 2011 06:30 PM
nickbeee
1G CL Tires, Wheels, & Suspension
37
Sep 20, 2007 10:21 AM
