power windows
Old Aug 19, 2010 | 09:15 AM
05whiteacura's Avatar
3rd Gear
power windows
i have a 05 RL with 105k. I recently had to replace the driver side door lock acuator, which set me back about 340 from the dealer. They said it was just normal wear and tear because the driver door is used the most. Now i am starting to realize that if i put all the windows down at the same time the driver side window goes up and down at abou thalf the speed of the other 3? Is this a sign of the motor about to wear out?...is there anything you can do to try to make it get back to speed or prolong the life of the motor? I am out of warranty and even little problems like this are costly at the dealer...any suggestions would be greatly appreciated.
Old Aug 19, 2010 | 09:31 AM
Chas2's Avatar
Does not sound good, but I would at least use the Honda silicone spray to lubricate the vertical sliding surfaces. This actually worked on my 2G Legend to help it move up and down faster, and was recommended on a 2G Legend site for all power windows on a regular basis. Those power windows were not the fastest.
Get the spray at your local Honda or Acura dealer for about $5 and is recommended for window tracks, door latches, etc.
Old Aug 19, 2010 | 10:21 AM
HEAVY_RL's Avatar
If you aren't comfortable tackling the fixes yourself I'd find a local Honda mechanic that you trust to handle it.
The key word being "trust", some will work on the side for far less money.
Old Aug 19, 2010 | 01:54 PM
3rd Gear
is there any diff in a honda certified mechanic vs a acura one?
Old Aug 19, 2010 | 02:35 PM
rtr's Avatar
rtr
RL owner
no there both a head ach! The best thing to do is to be friends with someone at the dealer and find out who is the best TECH in the hole area you live around then be friends with them and your car will be mint like mine. Let me know your problem and i will tell you the best way to fix it.
Old Aug 19, 2010 | 02:37 PM
rtr's Avatar
rtr
RL owner
oh yea lubing the window tracks is normal maintenance twice a year 100% silicone spray be sure to read the can.
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
