Pin stripe on rl, how to remove
Hello Guys I found a Silver 06 RL which dealer installed Pinstripe Can i remove Pinstripes from a silver car and would it be an issue after removal? It has been on the car since 06.
Regards.
Regards.
Paint or tape? Tape should peel right off (may leave some adhesive behind but that's easy to get off) but the paint under the stripe may look a little different until you give it a good polishing. Paint is not so easy to remove.
LL
LL
Respect Man i appreciate! the help. It looks like tape.
Just found out It's painted on not tape. Its not a ridiculous color but i am just not into pinstripes. Can a professional body shop remove this? would i be damaging the clear quote in anyway.
If not cleared over, and they most likely aren't, there are two things to try...lacquer thinner (shouldn't hurt the paint under...I often use it as a tar remover) or...believe it or not...Easy-Off Heavy Duty Oven Cleaner. Haven't tried it myself but have heard of it working very well with no damage to the underlying paint. Worth a shot.
LL
dainmezron
10-16-2015 06:56 PM
xsilverhawkx
09-28-2015 06:51 PM
