Oil Change
Old Oct 10, 2009 | 11:09 AM
rlerman's Avatar
Oil Change
In 20 years of changing oil, this RL has been the most difficult car I have ever had to change. This is the second time I have tried to change it and the second time I haven't had any luck. The drain plug will not come off, turning it counter-clockwise. I had the car jacked up with good access, but no luck, won't come off and the head of the bold is starting to round over.
I get free oil changes at the dealer, but it's 30 miles away and it's not what I want to do on Sat morning, but now have no choice.
BTW, I also tried to take the tire off to get better access and no luck with those lugs either, literally the lug wrench was starting to bend even with a breaker bar on it.
What's up with the torque specs on this car, unbelievable.
Old Oct 10, 2009 | 09:52 PM
Chas2's Avatar
Sounds like you are way over torqued. My dealer sets all the sticks to 90, which is close enough. Manual says 94 lbs-ft
Old Oct 11, 2009 | 05:37 AM
kirbyflorida's Avatar
The torque on the drain bolt is 34 pounds, should be easy, someone may have over torqued it.
Nothing wrong with the specs.
Old Oct 11, 2009 | 07:27 AM
rlerman's Avatar
I torque the lugs on my porsche to 90 and have no trouble getting them off with a 1/2" ratchet so I know it's not me that's the problem (though my wife will probably take issue with that). Firestone last rotated the tires so can't blame the dealer on this one. I wasn't kidding when I said the lug wrench was starting to bend, it was that tight...hope I don't get a flat.
As for the drain plug, no way it was torqued to 34 lb/ft. I think that because it has a crush washer on it, some of these guys think they can torque it down more. I'll have to let the dealer know when I take it in to back off on the drain plug and to re-torque the wheel lugs properly.
Old Oct 11, 2009 | 09:06 AM
Chas2's Avatar
Yea, places like Firestone use the impact wrenches, sometimes with no regard for torque settings. I have had lug bolts actually snap on other cars because it was over torqued so much.
Old Oct 11, 2009 | 03:59 PM
chaiwala's Avatar
Get one of these
Old Oct 11, 2009 | 04:56 PM
rlerman's Avatar
very cool, where do you get it? Not sure there is enough clearance on the RL.
Old Oct 11, 2009 | 05:19 PM
chaiwala's Avatar
http://www.quickoildrainvalve.com/Pr...oductCode=F106
Don't worry about clearance. The arm is spring loaded and you physically have to push it down and to the left/right to get it to drain. Get the F-106 without the nipple. I have used it for close to 8 years now and never had a problem with it even with the cars lowered
Old Jan 18, 2010 | 08:08 PM
cbrose's Avatar
2005 MDX & 2006 RL
I changed my '06's oil today in about 10 minutes. Same oil, filter and procedure as my MDX. I actually was surprised at how easy it was and was able to get the Mobil 1 oil and top Fram filter for under $30.00. Cheaper than taking it somewhere and worrying about how they're treating the car...
Old Jan 19, 2010 | 11:57 AM
danmm7's Avatar
Try to AVOID Fram oil filters at any cost!!! If you wonder why, search on the Internet and you'll find out.
Old Jan 20, 2010 | 12:09 PM
cbrose's Avatar
2005 MDX & 2006 RL
Yeah, I'm glad I spent the extra $2.50 on the Extra Guard filter versus the stock Fram. I think I'll be OK but will go with Mobil 1 or WIX next time.
Old Jan 20, 2010 | 02:38 PM
cbrose's Avatar
2005 MDX & 2006 RL
I meant Fram Xtended Guard filter, not Extra Guard.
mada51589
Jan 9, 2025 04:40 PM
robm
Sep 18, 2015 07:53 AM
ja4lyfe
ZDX
Sep 17, 2015 09:10 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
datadr
Sep 12, 2015 09:12 PM
