Oil maintenance reminder: How does it calculate?
Old Jan 20, 2010 | 11:59 AM
cbrose's Avatar
2005 MDX & 2006 RL
The maintenance reminder told me I had about 10% oil life left and it was a warm day in PA on Sunday, so I decided to change the oil. I believe the interval was over 5,000 miles and probably closer to 7,000. Does the RL calculate by mileage or is there a sensor that measures oil dirt and such? I refilled the RL with Mobil 1 and the Fram extended guard filter (though next time I'll probably go with WIX after reading some reviews). The Fram says that it cleans up to 10,000 miles, so I'm wondering if the maintenance reminder will go off based on miles or the status of the oil's dirt. If the filter really cleans that well, I should be able to get a little more life from the oil... Thanks.
Old Jan 20, 2010 | 12:45 PM
robarsan's Avatar
According to the owner's manual, it's based on engine operating conditions and engine revolutions.
Old Jan 20, 2010 | 12:57 PM
Chas2's Avatar
Right, in addition, here is some other info from the original 2005 RL introduction, but as you can see, it is an indirect monitoring of the oil; there is no direct inspection of the oil itself to test lubricity and contamination. I am sure there are also certain fixed variables, such as the assumption of the filtering capacity based on a Honda OEM filter, and the recommended API class 5W-20 oil, and not synthetic. I believe the only Acura requiring Mobil One synthetic is the turbocharged RDX.
http://www.hondanews.com/categories/757/releases/2091
MAINTENANCE MINDER SYSTEM
To eliminate unnecessary service stops while ensuring that the vehicle is properly maintained, the RL has a Maintenance Minder System that automatically monitors the vehicle's operating condition. When maintenance is required, the driver is alerted via a message on the Multi-information display.
The system monitors operating conditions such as oil and coolant temperature and engine speed to determine the proper service intervals. Depending on the operating conditions, oil change intervals can be extended to a maximum of 10,000 miles, potentially sparing the owner considerable money and inconvenience over the life of the car. The owner-resettable system monitors all normal service parts and systems, including oil and filter, tire rotation, air-cleaner, automatic transmission fluid, spark plugs, timing belt, coolant, brake pads and more. To prevent driver distraction, maintenance alerts are presented when the ignition is first turned on, not while driving.
Old Jan 20, 2010 | 12:59 PM
JPSMAN's Avatar
Basic algorithm based on the above information.....
Old Jan 20, 2010 | 03:48 PM
CFoote's Avatar
I thought fuel usage was also monitored, but maybe I'm wrong on that....
Old Jan 20, 2010 | 04:10 PM
getakey's Avatar
It monitors Brake Pads? Do you know what the threshold is for warning? I know I am getting close to needing new brakes.
IBankMouse
Jun 13, 2020 12:53 PM
acuratl26
Apr 23, 2020 07:30 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
LeVeL
Oct 18, 2015 04:19 PM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
