Oil
Old Jul 14, 2016 | 08:54 PM
wields's Avatar
Oil
What do you guys use on your Acura with 160k+ miles?
Old Jul 14, 2016 | 08:59 PM
Any oil you want with the right weight and viscosity . Doesn't matter.
Old Jul 15, 2016 | 09:37 AM
oo7spy's Avatar
Old Jul 15, 2016 | 09:41 AM
spot on.
if you are a novice, you can follow the advice that is given in the owners manual.
if you know the proper SAE weight and viscosity for your region, you can use that as well.
Old Jul 15, 2016 | 04:01 PM
RL09's Avatar
FkNo!TheyRdstroyinEvrting
1. A little search would have shown you there's a few threads on that.
Manual says 5w20; syntethic or not does not matter as long as it's API approved oil.
If you live in a relatively hotter climate and/or are often hard on the gas pedal, use 5w30.
But 5w20, what's in the manual, is generally what you should stick to.
Old Jul 18, 2016 | 12:51 PM
projektvertx's Avatar
Any API approved oil will do the job. Manual says 5W-20, that's what I use. I use Mobil 1 since my car's run on synthetic since day 1. I've been thinking of switching to Penzoil Platinum or Ultra Platinum when my current Mobil 1 supplies run out since they use natural gas as the base oil. Some will say 5W-30 or 0W-30 depending on where you live.
I feel like this is like asking what kind of underwear you wear. Ask 10 different people you'll get 10 different answers. Just my thoughts
Old Jul 18, 2016 | 03:37 PM
RL09's Avatar
I'm using this Castrol EDGE SPT 5W20 for Automobile 6 x 1 (costs less in store)
Old Jul 18, 2016 | 05:14 PM
rlerman's Avatar
I have 115k on the clock. Been using Mobil 1 5w-20 since I got the car in 08 with 43k on it. It burns almost no oil.
Old Jul 18, 2016 | 05:17 PM
Well that just disproves my underwear theory
Old Jul 19, 2016 | 11:59 AM
cobra10363's Avatar
I use Castrol GTX High Mileage Oil which is part synthetic and i buy it at Walmart.. Why? Because it's the cheapest place.. My RL has 79k and does not burn oil..
Old Nov 11, 2016 | 04:29 PM
RL09's Avatar
I read somewhere that between 20 and 30, 20 will give better mileage and 30 less. Cost of better mileage is more engine wear.
Is it safe to go 5w30 in cold weather?
Old Nov 12, 2016 | 08:13 AM
oo7spy's Avatar
You don't need 30. Only very hot areas, like Texas to Southern California, need 30 weight. You need to focus more on the winter weight. If you go conventional, use factory recommended 5W-20. If you go synthetic, get 0W-20.
There is no engine wear difference between 20 and 30 at 70 degrees. Maybe at 110.
Old Nov 22, 2016 | 02:55 PM
TonyCD's Avatar
+1 to 007's answer, as usual.
I happen to use 0-20 synth, since I live in a colder climate. And yes, 30 will lower gas mileage a bit compared to 20.
Old Nov 23, 2016 | 01:37 AM
beekermartin's Avatar
I have been using 5W20 Mobil 1 since I got my 2005 With 106k on it. I developed a main seal leak at just over 150k. I probably should have used high mileage Mobil 1 since it has additives that help to keep seals from leaking as they age. Supposedly. I don't know if it would have helped or not but seems to make sense since the high mileage oil does have more additives. Who knows. I have always used regular Mobil 1 in all my cars and this is my first main seal leak.
imrinfam0uz
Jun 1, 2016 11:11 AM
New Car TL-S
Apr 29, 2016 06:44 AM
Cooldude01
4G TL Problems & Fixes
Apr 7, 2016 09:56 PM
gatrhumpy
Feb 23, 2016 07:39 AM
Skirmich
1/2G MDX (2001-2013)
26
Feb 21, 2016 01:38 AM
