Official RL TSB thread
Old Oct 10, 2009 | 07:05 PM
neuronbob's Avatar
All TSBs for the 2G RL from 2005 to the end of December 2009 are listed below as links:
05-005 Product Update: Front Door Speakers and Driver’s MPCS Unit
05-006 Product Update: AcuraLink Control Unit Does Not Receive Real-Time Traffic
05-008 No Sound From the Audio System
05-021 Rattle From Front Suspension Area or Front Brakes Squeal At Low Speed
05-022 Product Update: AcuraLink Control Unit May Cause Excessive Battery Drain, May Refresh XM Program Data Slowly, May Not Receive Real-Time Traffic
05-026 No Real-Time Traffic on the Display
05-027 Product Update: PCM Software May Not Allow the Transmission to Upshift Product Update: Into 4th Gear or May Cause an Engine Shudder
05-028 Product Update: OnStar Control Unit May Lose Minutes
05-030 Rattle From the Rear Shelf
05-031 MIL Comes On With DTC P0135 or P0155
05-040 2006 RL: TQI and New Model Information
05-045 Product Improvement Campaign: Tire Valve Cap Replacement
06-017 Instrument Panel or Center Console Creaks or Rattles
06-023 MIL Comes On With DTC P0116
06-030 2007 RL: TQI Information
06-047 Auto Door Unlock/Lock Does Not Work When Shifting To/From Park
06-049 AFS Indicator Comes On With DTC B2130
06-050 Warranty Extension: Vehicle Warranty Mileage
07-001 Door Mirrors Stay Tilted Down After Shifting Out of Reverse
07-003 Fuel Vapor Lock
07-009 Windshield Wiper Doesn’t Clean Snow or Slush From the Windshield
07-017 Safety Recall: Fuel Pump Relay May Cause Engine No-Start or Stalling
07-026 Pinging, Rattling, or Squealing During Light Acceleration
07-029 Rear Brakes Squeal
07-034 2008 RL PQI
07-041 Brake Pedal low and feels soft
07-047 Improving Elevation and Clock Settings--2007 Base RL
07-061 Safety Recall: Power Steering Feed Hose Leak
08-002 Front Accessory Power Socket Lid Won’t Stay Closed (2005)
08-003 Product Update: AcuraLink Does Not Receive Messages From Acura (2008 RL)
08-006 Malfunction Indicator Light Comes On With DTC P0401
08-022 Outside Rearview Mirror Is Loose (2005-2006 RL)
08-029 2009–10 RL: TQI of the Navigation System
08-030 2009 RL: TQI Information
08-046 Audio Unit Displays CODE After Using Auto Select (2009 RL w/o navi)
08-049 Drive Belt Auto-Tensioner Replacement Instructions
08-050 Time on Display Changes Randomly
08-059 Front Door Outer Handle Sensor Does Not Unlock the Door (2005-2008 RL)
09-007 Long Crank Time or Hard Start After “Hot/Warm Soak” (2009 RL)
09-013 Immobilizer System (Type 5)
09-015 OnStar Control Unit Replacement for Lost Minutes (Units)
09-021 2009 RL: MIL Comes On With DTC P0455 or P0456 (2009 RL)
09-022 High Mount Brake Light Cover Is Loose or Falls Off
09-025 Steering Angle Sensor Causes False SAS, VSA, CMBS, or AFS Messages
09-026 2010 RL: TQI Information
09-042 Door Outer Handle Cover Is Loose or Missing
Old Jul 26, 2010 | 07:27 AM
kssod's Avatar
can't access
hey, what's with the links now not working with Safari or Firefox?
Old Jul 26, 2010 | 06:48 PM
poppintec's Avatar
none of these links are working
Old Aug 7, 2010 | 03:20 PM
neuronbob's Avatar
Edit: The pages require Windows. Not only that, they require installation of specific Honda software. Weird. If I'd known this change was coming, I would have downloaded all the pdfs.
Old Aug 9, 2010 | 11:26 AM
rettenhu's Avatar
Do you have a link to download the necessary software or is this no longer available to the general user community?
Old Aug 24, 2010 | 02:56 PM
Dopes6070's Avatar
Looks like you also have to be an employee with a login... This sucks!
Old Aug 24, 2010 | 05:30 PM
Chas2's Avatar
there may be a link issue with the thread.
Try this address, then vary the TSB number (as in B06-047) to get what you want.
http://techinfo.honda.com/Rjanisis/pubs/SB/B06-047.PDF
Old Aug 26, 2010 | 08:09 PM
neuronbob's Avatar
The problem has been fixed for me thanks to the other mods. See the new RL Garage at the top of the forum.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
thegipper
Sep 28, 2015 01:01 PM
