OEM/ LED Map Light Fade Video
Old Aug 1, 2011 | 05:39 PM
thephantom's Avatar
For those of you who are curious if the LED fades faster than OEM bulbs:
http://www.youtube.com/watch?v=oroxuXCo20M
Old Aug 1, 2011 | 08:00 PM
tnobori1's Avatar
Missing my
Very useful vid! Thanks Phantom!
Old Aug 2, 2011 | 06:40 AM
thephantom's Avatar
My pleasure.
Old Aug 2, 2011 | 06:58 AM
Chas2's Avatar
What did you use for your LED???
A link would be perfect.
Thanks!
Old Aug 2, 2011 | 11:10 AM
thephantom's Avatar
Thanks!
Check out this thread: https://acurazine.com/forums/2g-rl-2005-2012-76/led-bulb-question-826215/
"T10 led" and "31mm Festoon" are all you need to search with. You need 10 T10 bulbs and 2 31mm Festoon bulbs." - oo7spy
The 31mm replaces the two front interior map lights.
Where do all 10 T10's go?
2 in the rear interior
2 in the two front doors
2 in the two rear doors
2 - License plate
2 in the trunk
Old Aug 2, 2011 | 11:51 AM
oo7spy's Avatar
Swap those front and rear interior and your are correct. (The 31mm go in the back seat.)
Old Aug 2, 2011 | 12:25 PM
thephantom's Avatar
I stand corrected.
Old Aug 2, 2011 | 12:28 PM
Chas2's Avatar
Ah yes, but I mean what source did you go to...for example VLED, superbrightleds, putco, etc.
Old Aug 2, 2011 | 12:29 PM
thephantom's Avatar
I got mine from www.superbrightleds.com
Old Aug 2, 2011 | 04:11 PM
23109VC's Avatar
phantom -
how do the ones in the doors, map, and license plate look at night? too bright? to "bluish"..
I like the look of the slightly bluish / super white bulbs... similar to what some high end cars have OEM... I saw a lexus the other night and his license plate lights looked like super white LEDs..... they don't really look blue..but they are NOT yellowish like our OEM lights...
when you ordered your bulbs were they "super white" or what color were they classified as on the website?
how to the leds from yhoru source, superbrightleds compare to the vled place that others here h ave used?? anyone know?
i'm about to order some.
out of curiosity - what did it cost you to get all these bulbs?
Old Aug 2, 2011 | 05:19 PM
Chas2's Avatar
Sorry for all the badgering, but there are so many T10's
I would assume we are talking warm white whp6
http://www.superbrightleds.com/cgi-b...Fwled-whp6.htm
or
the lower power Whp5
http://www.superbrightleds.com/cgi-b...FWLED-xHP5.htm
I was actually looking at these...because of the much higher output specs, but they may be too bright...
http://www.v-leds.com/Interior-LED-B...-p5768086.html
Thanks in advance!
Old Aug 2, 2011 | 08:27 PM
thephantom's Avatar
or
Thanks in advance!
No worries. I was in your shoes a couple of weeks ago and I badgered everyone here.
This is what I got:
T10: http://www.superbrightleds.com/cgi-b...%2FWLED-x5.htm
These will replace:
2 License plate
2 in the trunk
31mm Festoon: http://www.superbrightleds.com/cgi-b...on_3022-xx.htm
These will replace:
2 rear interior map/ dome lights.
All of them in NATURAL WHITE. The Natural White is more like our headlights (5500K to 6000K color). They are not as bright as the OEM bulbs, but not much dimmer. I actually love the brightness of these LED's because not only do they cast a nice "white" light in the interior, but it's also just the right brightness for me, so I'm not blinded by the sudden brightness of the OEM bulbs when I open the door.
The puddle lights on the doors work well in the dark by casting light over a fairly large area on the ground.
The trunk lights are definite dimmer than the OEM, but it's sufficient for my needs.
The license plate lights are just perfect.
I got everything in natural white because I wanted the "natural" lighting and not the "mood" coloring.
Hope this helps.
Old Aug 2, 2011 | 08:51 PM
Chas2's Avatar
Very helpful, thanks!
Old Aug 3, 2011 | 12:36 PM
thephantom's Avatar
Sure thing.
Old Aug 17, 2011 | 01:58 PM
thephantom's Avatar
Update:
I installed Sylvania 7440ST SilverStar to replace my reverse lights, and man, what a night and day difference!
I also installed Sylvania 9005SU SilverStar Ultra to replace my high beams. They were a bit of a pain to install, but not bad. They are brighter, but they're not HID-color matching.
Old Aug 17, 2011 | 03:22 PM
oo7spy's Avatar
I have the same high beams and am rather disappointed. HIDs just blow them out of the water.
Old Aug 17, 2011 | 03:39 PM
thephantom's Avatar
For me, it was an improvement from the OEM bulb, so I am ok with it. However, I was told these bulbs don't last as long as OEM's, so I have a feeling I'll be replacing these in the near future with something different.
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
oyayjoe
Jan 1, 2019 10:17 PM
oyayjoe
Sep 12, 2015 04:40 PM
