My RL shut off while accelerating...why?
Old Mar 30, 2012 | 05:49 PM
vb9594's Avatar
Heading home from work and I am making a right hand turn onto the highway...as I do, my '06 RL suddenly shuts down and is completely dead. I shift into neutral, turn the key and she turns right back on. She acted like the battery had died and made me put the radio code back in, and all my radio presets are gone.
I replaced the battery myself a couple of weeks ago. I popped the hood and checked all the battery connections and they seem fine. Can anyone give me any theories on what caused this? As always, your help is much appreciated- thanks!
Old Mar 30, 2012 | 09:39 PM
antle1101's Avatar
If you replaced your battery, it could be a bad altenator. Just a theory. To check if your altenator is bad, you will need a multimeter. Set the positive to positive and negative to negative (from the multimeter to your battery). Turn multimeter to 20dc. Then it should read a number (example 12.5). Start the engine and recheck the numbers should be slightly higher. If the numbers are decreasing you have a bad altenator. Hope this helps.
Old Mar 30, 2012 | 09:51 PM
HEAVY_RL's Avatar
How old was the battery you put in?
Old Mar 30, 2012 | 10:41 PM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
I doubt it's the battery if it started back up. It may be a fuel pump issue.
Old Mar 31, 2012 | 07:21 AM
typeR's Avatar
fuel pump ? thats why he needed radio code ...
Old Mar 31, 2012 | 07:35 AM
HEAVY_RL's Avatar
Throwing darts is fun.
Old Mar 31, 2012 | 07:47 AM
shahram72's Avatar
Yeah, sounds electrical to me. Car suffered a voltage drop and the computer shut down.
Old Mar 31, 2012 | 08:02 AM
GoHawks's Avatar
Oops. I missed that part.
It's still electrical and probably a short as shahram said.
If the battery was dead the alternator would be able to keep the car running. If the alternator died, the car would be drawing off of the battery until it completely died. Once dead, there is no way it would start again and continue to run.
There's a short somewhere.
Old Mar 31, 2012 | 08:42 AM
Maintenanceman's Avatar
Bad contact in main relay? My Accord did that sometimes before i changed it.
Old Mar 31, 2012 | 09:06 AM
neuronbob's Avatar
You SURE the battery connects are not a little loose? This just sounds suspicious for a position-related malfunction.
Old Mar 31, 2012 | 10:03 AM
guss_90's Avatar
This happens to me 1 time. The reason, Loose terminal Negative connector at battery. If you repalce the battery, you wil be ok.
Old Mar 31, 2012 | 11:39 AM
Carbon Legend's Avatar
also check the chassis ground wire from the battery
Old Mar 31, 2012 | 12:32 PM
getakey's Avatar
I bet loose connection at the battery. I know he said he checked, but the positive connection is a bit weird if you ask me.
Old Mar 31, 2012 | 04:03 PM
steve807's Avatar
that other end of the cable from the battery is critical
happened to me years ago, not on an Acura
very embarrassing once you find it (based on the 100 other things you tend to check first)
Old Apr 1, 2012 | 01:34 PM
vb9594's Avatar
Ok...I went out and re-did the battery connections...cleaned and tightened them, etc. I will let you know if it happens again. Thanks to all for your assistance here!
Old Apr 1, 2012 | 01:46 PM
HEAVY_RL's Avatar
good luck
Puma Jim
20
Oct 20, 2016 11:59 AM
copmagnet82
4G TL Problems & Fixes
Jun 29, 2016 08:09 AM
rockyboy
Sep 29, 2015 12:05 AM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
prbori
Sep 27, 2015 01:37 AM
