lock issues
Old Jan 17, 2012 | 11:07 PM
merlin the wrench's Avatar
lock issues
we have something that started this weekend on our 2006 RL. In the past the locks have been flawless but starting Friday when we got out of the car and pressed either of the FOBs, -> UNLOCK it will cycle the locks as always but sometimes -> LOCK does nothing on either FOB. If we open and close the driver's door it will start working again where it locks when when we press LOCK on either FOB. Then we noticed that everytime we took off from a stop the locks would cycle softly. Next a few miles later we noticed that if we pressed the lock / unlock switch on the door when driving the driver door was not locking but the other 3 doors were - hence the soft sound. I moved the driver's door lock manually a few times and it has worked Ok ever since but I am concerned that since this happened a couple of times during the weekend we may have a part going bad. Any ideas based on others who might have similar issues?
Old Jan 18, 2012 | 06:43 AM
HEAVY_RL's Avatar
To go the easy and free route with out changing anything, I'd say your car needs to be re-booted by pulling the battery cable.
Old Jan 18, 2012 | 09:29 AM
mitchkramez's Avatar
Try the re-boot first, if that doesn't do it, look at the TSB in the garage:
TSB 06-047: (2005-2006 RL) Auto Door Unlock/Lock Does Not Work When Shifting To/From Park
What you describe is very similar to what I had happening on my '05, dealer took care of it since I noticed it the day I picked it up.
Old Jan 18, 2012 | 09:35 AM
oo7spy's Avatar
Do you know the cause of the TSB? It sounds to me like the door lock switch is malfunctioning, and since the driver door controls all the other doors in this car, it could very well be the culprit.
Old Jan 18, 2012 | 09:50 AM
007, The cause of the TSB is 2 fold - at least on the '05. 1 Is the transmission position range sensor which triggers the auto lock out of park etc (but affects the door locking in general) and something in the drivers fuse panel - for '-05 they have the tech replace the entire panel... to the tune of $600 for whole setup, but if I remember the '06 it's just the range switch going bad which is a whole lot cheaper.
Another symptom I had on mine was that with the auto door locks turned on (lock when leaving park, and unlock when entering park) sometimes the doors would lock randomly while driving...
Hopefully this will at least get you pointed in the right direction!
Old Feb 2, 2012 | 10:43 PM
jerztl's Avatar
2005 RL black on black
About a month ago my auto locking stopped working.So locking stopped working so now when i lock the car the lights do not go on like they use to and dont hear the little beep when i close it.
Does anyone know how to fix this?
Old Feb 3, 2012 | 07:01 AM
HEAVY_RL's Avatar
Did you try a battery reset?
Old Feb 7, 2012 | 05:24 PM
jerztl's Avatar
I tried the battery reset but same thing still no auto lock or beep with the lights when i lock it.
Old Feb 7, 2012 | 07:14 PM
HEAVY_RL's Avatar
Ok, so when you get in does it recognize that you are Driver 1 or 2 on the MID?
Old Feb 7, 2012 | 10:45 PM
jerztl's Avatar
After the reset it does display driver 1...
Old Feb 8, 2012 | 08:10 AM
HEAVY_RL's Avatar
ok, check this thread out
https://acurazine.com/forums/showthread.php?t=693946
specifically post 11.
tman570
Jun 11, 2019 07:56 AM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
Azonics
Sep 22, 2015 05:28 PM
Username 0
2G TSX Problems & Fixes
Sep 11, 2015 09:50 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
