keyfob problem?
Old Sep 29, 2009 | 09:29 PM
Richbum's Avatar
keyfob problem?
So today I got in the car and tried to turn on the car, but it wouldn't let me turn the key thing. It would only turn about 1millimeter, and the steering wheel would tilt down and the welcome screen would turn on for a quick second, then it would tilt back up and wouldn't let me turn the key. but after wiggling it back and forth for a good minute it finally just let me turn it on. Right afterward it would turn on and off really easily. I drive the car everywhere and it would work perfectly, then it would randomly do it again maybe a few days later.
Has this ever happened to anyone? Is is the car not sensing the keyfob is in the car? or is it the turning thing thats malfunctioning? I'm still under waranty so I'm probably going to take it to Acura soon, but i'm afraid they're gonna turn me away because i cannot replicate it on the spot.
Old Sep 29, 2009 | 09:38 PM
drolds72's Avatar
is the steering wheel getting locked? Next time it happens try hanging some pressure on the left side of the wheel when you try to start it and the key does not want to turn.
Old Sep 29, 2009 | 11:18 PM
Richbum's Avatar
no. steering wheel is not locked. the only thing thats locked is the key from turning. i get it to work eventually by twitching it back and forth a few times.
Old Sep 29, 2009 | 11:23 PM
lstevennl's Avatar
had this problem one time when battery on key fob was weak. try checking out the battery on the key fob
Old Sep 30, 2009 | 09:58 AM
sirfergy's Avatar
I brought a keyfob into the dealer to be programmed and the next day it had that same issue. I thought it was the batteries so I swapped them out with the ones in my other keyfob and the problem didn't go away. I took it back to the dealer and they ran some tests on it and concluded it could no longer hold programming.
Old Sep 30, 2009 | 12:29 PM
JuanCT's Avatar
This happened to me as well once..it seemed as if the steering wheel got confused!! I think the wheel was just locked or it didnt recognize my key for some reason
Old Oct 1, 2009 | 03:05 PM
alex1372's Avatar
Happened to me few times also... But i figured that I started to turn the knob before it recognizes the remote. To fix it, I locked the doors by pressing button on the remote, the unlock it by remote, close the door and voila! - I could turn the knob
Old Oct 1, 2009 | 10:14 PM
Richbum's Avatar
i actually did that. i locked and unlocked the car and did everything it wouldn't work. I got fustrated that kept wiggling the keyfob until eventually it gave in and turned on.. LOL. I guess i'll take it to acura this weekend and talk to them about it.
Old Oct 2, 2009 | 02:32 PM
Chas2's Avatar
Try unlinking both remotes, then relink them both and see what happens. Instructions in the OM
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
