installed ur stock size pulley
I am still curious about this and I asked about how fuel efficiency changes after installing UR pulley in my previous thread. If it revs so much faster, don't you get lower mpg? I'm quite confused.
Glad you like it. I still wish someone would do pre- and post-install dynos with this modification. Maybe I'll do it when my factory warranty runs out.
The idea is that the motor CAN wind out with less work, so it does so more quickly at the same level of fuel input. The lightweight pulleys reduce engine inertia, enabling the car to accellerate/rev with less work. If he drives the same way he did before the swap, he'll get better mileage, because the motor doesn't work as hard.
It was like 20-30 min from my mechanic, said it came right off with impact gun and the holder. I told him about how hard I heard it was, he said it came right off, mybe cuz its a newer car from what he said?
I don't know, but I am guessing billet machined aircraft aluminum is a lot more expensive than steel. This is, after all, a mass produced car, at least, it was designed to be.
That part cannot be that expensive, and if they get improvement it is cheap.
After all, it has alum suspension comps, alum calipers, very costly, carbon shaft, so I do not get it.
I still think it has to do with smooth shifts and some slamming on the tranny parts.
Former Sponsor
If you look at UR's homepage they are concentrating on marketing how the pulleys increase MPG: www.unorthodoxracing.com
How do Unorthodox Racing pulleys give me more power?
Weight reduction is how we are able to increase Horsepower! Each pound of weight removed from the crankshaft is worth approximately 2.7HP and the gains jump even more dramatically with forced induction, nitrous and variable valve timing. Only 15-20% of the gains from our pulleys come from underdriving. The diameter of each of our crank pulleys is reduced up to 20%. We tailor the exact amount of underdrive to each vehicle to maintain factory specified accessory output and performance. We fully maintain all accessory output minimums like air conditioning efficiency, power steering feel, and voltage (minimum allowable voltage 12v) even at idle with everything electrical on in the car. There are no adverse effects from using any of our pulley versions. Bolt them on and forget about them, then just follow your vehicles normal maintenance schedule.
We have these in stock. http://store.excelerateperformance.com
020611402 is the Ultra S underdrive crank pulley (requires new belt)
020611412 is the Ultra Sc stock size crank pulley
Former Sponsor
Perhaps I'm alone but I have avoided your website due to it's complicated listings for individual vehicles. Too many universal parts are listed and makes finding one item too time consuming-at least for me. I would have purchased a few items from you by now if not for that. Again-perhaps it is just me, I like things simple.
I know it's hard to read critical input regarding one's website and that 470hpGS400 could do all those things you suggest, but I hope you get the message that it's just input from a potential customer. In his case, it's a potential customer with a track record of spending money on his cars...check out the rebadged Hyundai Xcell he painted like a Lexus! ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
Seriously, I have also had some frustration using your site, and I figured out the "hide universals" trick. This isn't your fault unless you're the programmer, and I know it's harder to fix or change than many understand.
cycdaniel
12-17-2019 10:58 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
