I-021: Need help with reset of tpms warning on NAV
Old Aug 25, 2010 | 08:24 PM
BIGJ1875's Avatar
Hello,
I have a 2006 RL i got a flat on the right rear tire had to put the spare on for 2 days then replaced the back 2 tires the TPMS on the cluster works fine and shows the reading but i have a message stuck in the nav unit under info cant figure out how to get rid of it if anyone knows a way beside going to the dealer please let me know
Old Aug 29, 2010 | 04:20 PM
dannyV's Avatar
Most of the messages that come up on the nav screen can just be deleted if you open it.
Old Aug 31, 2010 | 08:08 PM
BIGJ1875's Avatar
tried that no delete option.
Old Sep 2, 2010 | 02:00 PM
JPSMAN's Avatar
I had the same issue with an AFS message was displayed. It only went away when a dealer ran the codes and reset everything.
Old Sep 2, 2010 | 02:35 PM
getakey's Avatar
if you listen to the message, so it shows as "read", then it should go away after some time. Not sure the exact timeframe, but the messages do eventually clear
Old Sep 2, 2010 | 03:08 PM
MRG061's Avatar
easy, do this at your own risk, do not modify any settings.
hold down map guide, menu, cancel, on the navigation.
go to xm selection, go to diagnostic info, choose message thats annoying you, and choose delete.
Old Sep 3, 2010 | 11:24 AM
getakey's Avatar
I looked at messages last night and there is a Read and Delete option. Are you saying the Delete option is not there for this specific message?
Old Sep 3, 2010 | 11:51 AM
AT&SF's Avatar
2010 Acura RL
This is the way to reset it.
MRG061
New Member
Trader Rating: (0)
Old Sep 3, 2010 | 11:15 PM
jmlaser's Avatar
^ ahhh yes the secret screens. I have done this several times before and it works.
Old Jul 28, 2015 | 11:16 AM
Llaso apso's Avatar
Clear error messages
Thanks man! That worked super. It is nice to see some user functionality for diagnostics without dealer involvement
QUOTE=AT&SF;12310908]
MRG061
New Member
Trader Rating: (0)
[/QUOTE]
Old Jul 28, 2015 | 05:37 PM
rlerman's Avatar
I don't have a diagnostic selection. I have xm (hip). I select it and it gives me two options system link and Ecu.
Old Jul 28, 2015 | 06:28 PM
oo7spy's Avatar
Map guide + menu + cancel does nothing on your car?
Old Jul 28, 2015 | 07:47 PM
rlerman's Avatar
It gives me a menu of about 12 options, but none are diagnostic. One says xm as I posted. Not sure what to choose.
Old Jul 29, 2015 | 03:10 PM
oo7spy's Avatar
I doubt any of them will spontaneously combust your car, so just start pressing buttons. That's how kids learn computers.
Old Sep 16, 2015 | 08:36 PM
NathanJax's Avatar
It worked...
Just tried it as I had a headlight message I couldn't delete. After holding down map guide, menu, cancel, on the navigation.
Went to XM (HIP)
XM (HIP) ECU
And then went in to Diagnostic Info
Old Sep 18, 2015 | 07:19 AM
rlerman's Avatar
Thanks, just did this, worked.
Old Sep 22, 2015 | 07:01 PM
shahram72's Avatar
Oh man thanks so much! I just removed years of codes from 2 dead batteries and a dead alternator. All clean now! No HDS tool needed!
Jul 16, 2017 07:33 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
RobbDizzle
Oct 15, 2015 11:16 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
