HID headlights
Old Feb 22, 2015 | 07:32 AM
RL_life05's Avatar
HID headlights
I just replaced my HID bulbs about three months ago maybe less, and one of them just went out again. So could it be an electrical issue, the headlight assembly, or just the bulb?
________________
Acura RL 2005: 12" dual subwoofers
Old Feb 22, 2015 | 08:01 AM
oo7spy's Avatar
What kind of bulbs did you use? To test the failure, take the good bulb to the other side. If it works, the other bulb is bad. If it doesn't, your ballast is probably bad.
Old Feb 22, 2015 | 08:34 AM
RL_life05's Avatar
HID Xenon D2S 20000k bulbs
Old Feb 22, 2015 | 09:42 AM
NathanJax's Avatar
This!
Do you even get any usable light from 20,000k bulbs?
Old Feb 22, 2015 | 10:37 AM
RL_life05's Avatar
Originally Posted by NathanJax
This!
yes it gives off a light blue type of color.
Old Feb 22, 2015 | 08:37 PM
oo7spy's Avatar
20,000k...
If your description is accurate to the product you bought, I am willing to bet just about anything your bulbs are worthless.
Old Feb 24, 2015 | 08:19 AM
this cant be real life?
Old Feb 24, 2015 | 03:28 PM
stevieray's Avatar
2007 LSM KB1 Tech w/CMBS
A 20,000K bulb would be the lighting equivalent of a sub-sonic dog whistle. Your brightness rating would be LESS than those incredibly stupid yellow bulbs that riceboyz stick in their Civics. Go 4300, 5000or 6000K or go home before you kill yourself or someone else.
Old Mar 1, 2015 | 12:32 PM
Carbon Legend's Avatar
say goodbye to your projector bowls i bet those things are so pitted and flaking now from all the UV from the bulb
Old Mar 13, 2015 | 12:03 PM
memphes.d's Avatar
4th Gear
Hey RL_Life 05,
Did your headlamp issue get resolved..?
So, kelvin rating are the OEM bulbs?
Here's my issue - my passenger side bulb turned pink about a 2 weeks ago. After some reading on this forum, I took the car in for a service at Courtesy Acura and asked them to replace the bulbs on both driver side and passenger side. After the service, the one on the driver side looked normal (ie - white, with a bluish tint) whereas the one on the passenger side looked almost like halogen.
I took the car back in, and now they've replace the one on the driver side to look halogenish too. :s
I am unable to support my argument because the SA thinks it looks white, but I can bet it doesn't. So, to have a technical argument, I probably need to talk about KELVIN ratings..
Old Mar 13, 2015 | 02:27 PM
oo7spy's Avatar
OEM HID bulbs are 4100 or 4300K. I don't remember which exactly. Have the SA pull another Acura up next to yours and compare the light against a wall. That will tell you right away.
Also, I hate to tell you, but if you paid for dealer bulbs, you got up-charged at least 100%. You could have bought the best bulb on the market for cheaper.
Old Mar 13, 2015 | 02:30 PM
NathanJax's Avatar
The kelvin rating should be the same on both bulbs. If one bulb is changing colors, it's going bad. Usually if that happens, you replace both bulbs so the color is the same on both sides. OEM on a lot of vehicles is around 4300k, because that's your best light. Anything too much more or less and you start loosing light output.
Old Mar 14, 2015 | 08:48 PM
TERRY A KHAN's Avatar
Make long story short, been through this with my previous 05.
Used after market cheap bulbs which lasted a month.
The factory bulbs was Osram, but used Philips OEM 4300K which was about 100.00 per bulb and worked perfectly.
My 2011 RL uses the exact bulb as the 05.
Replace your bulbs with high quality OEM.
Old Mar 16, 2015 | 04:43 PM
RL_life05's Avatar
All is good I had 10k bulbs in my car, what they said was that the bulb was loose, so that was an easy fix, and now i have 8k's for my HID's now.
Old Mar 16, 2015 | 05:57 PM
oo7spy's Avatar
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
