HFL Caller ID Problem
Is everyone with a '05-'08 KB1 getting Caller ID info on the MID if they have an Apple product? I have an iPhone 6 Plus / iOS 12.4.3 and I no longer get Caller ID. What's weird is that if there's a 2nd call that comes in, I get ID on that call but not the original one. Can't figure out if this is an incompatibility issue between HFL and the iOS version or if it's just my phone. Everything else works just fine, I can answer calls as needed with HFL, have signal & battery strength on the MID, just no Caller ID anymore and since we all get so many junk calls from telemarketers, I'd like to be able to screen the calls without having to pull the phone out of my pocket. Thanks!
I think y'all are misunderstanding what I'm asking. I don't expect to get contact names or address books. I had to replace my original HFL module with one from a junkyard and now I don't even get the phone number displayed on the MID and I don't know if its a HFL/Bluetooth thing or or an Apple iOS thing. It's definitely not a setting on the MID. I was hoping that someone on here a with a KB1 with an iPhone 6 or newer with iOS version 12.4 could tell me if they still get the number displayed on the MID so I can figure out if my problem is a common one or just a one-off. Thanks---
I think i read somewhere here in the past that units like the HFL need to be programmed by dealer. But I'm uncertain. I suspect this more than anything else.
You did not say you replced your hfl unit. Obviously it may have something to do with that other than an ios or mid issue!
I seriously doubt it has anythin to do with the iphone 6. You can pair a different phone and try to make sure. Also check if your caller ID service is ok.
if all ok, then maybe that module is faulty, or some kind of programming.... it does seem odd.
TSX-S2000
14
Jun 23, 2016 02:04 AM
djdonte
Jan 1, 2013 01:53 PM
ed111
Jan 31, 2008 09:12 AM
