Help Running Wires.
Old Nov 22, 2014 | 01:33 PM
ChocBoyWonder's Avatar
Help Running Wires.
I need to run wires from inside the car (dash) through to the engine area. Has anyone done this before? I am trying to figure out the best way to make this happen but the answer isn't obvious. Anyone have any thoughts and or ideas?
Old Nov 22, 2014 | 10:41 PM
oo7spy's Avatar
Take off the dead pedal. There is supposedly a hole large enough for an amp wire there.
Old Nov 23, 2014 | 06:39 AM
Thanks, I'll look into that.
Old Dec 9, 2014 | 03:28 PM
I tried feeling behind the dead pedal and taking off the wheel and examining under the hood to see if I could find a place optimal to get the wire through but I found nothing.
Do you remember reading about the dead pedal in a thread or know anyone I may be able to ask? I'm going to look at running it from the glove thorugh the side and under the pillar which would bring it right through the corner underneath the windshield on the passenger side.
Any thoughts?
Old Dec 10, 2014 | 12:43 AM
Sniffles's Avatar
Dead pedal is on your left. Sorry if the pic isn't the best
Old Dec 10, 2014 | 02:06 AM
Attachment 26680
Is that your setup? Where on the other side does it run to and did you make that hole or is it there? I'll need to look again.
Old Dec 10, 2014 | 07:00 AM
HEAVY_RL's Avatar
you took the wheel off to find a wire in the engine bay?
Old Dec 10, 2014 | 07:39 AM
I took the wheel off to have more room to look to see where the wire would end up if I ran behind the dead pedal. i cant see where I might have to look for it.
Old Dec 10, 2014 | 07:54 AM
oo7spy's Avatar
Here is how I ran mine. I chose to drill Ito the firewall, and my hole came out just below the brake booster. This may give you some perspective about where to expect the wire.
https://acurazine.com/forums/audio-b...emoval-813630/
Old Dec 10, 2014 | 08:31 AM
HEAVY_RL's Avatar
I would expect that if you are under the dead pedal, which is in the cabin and behind the door then the wire would pop out in the engine bay INSIDE the fender well.
Old Dec 10, 2014 | 10:20 AM
This is what I was figuring. Wish I could avoid but oh well, I will have at it if it warms up one day.
Old Dec 14, 2014 | 04:53 AM
Sniffles's Avatar
I think it's drilled thru. I had my headlight retrofitted and that's how he wired it. It's too cold to take anything off but I'll take a look if it warms up lol
Old Dec 15, 2014 | 07:10 AM
I am going to investigate to see what is directly behind the front dash after I take the radio out again. I'm going to clean up some wires back there.
Old Dec 19, 2014 | 10:51 PM
nynruas's Avatar
Are you running wire for amp battery? I ran a 4 gauge wire from the battery inside the fender and through the wall (through the rubber wire thingy for the door wires). If you have a look at the link below, you'll know what I mean..lol. It is the picture that shows about 3" of blue wire when you open the door. If it was a black wire, you probably would never notice it.
https://acurazine.com/forums/audio-b...amp-rl-810416/
Old Dec 20, 2014 | 12:38 PM
This is something that I'm looking at doing the thing is I don't want to run it to the trunk. I am running it to behind the radio area.
Specmiata82
Sep 30, 2015 10:04 AM
NorthWestAnimal
Sep 28, 2015 06:20 PM
MikeJM310
Sep 24, 2015 07:24 PM
TL14
Sep 24, 2015 04:37 PM
