Gear ratios - question
Old Jul 14, 2011 | 11:53 PM
rlx015's Avatar
I found this specification where gear ratios look pretty good on the paper - however, I wanted to share my experience on recently bought RL and ensure I am not missing anything:
I feel that first and then second gear takes too long to switch into the higher gear when I normally accelerate. I start from the traffic light and go up to 3000-3500rpm until it switches into second gear; now if I really start moving slow than it switches around 2500-3000. My question is: how normal this is? I drove V6 3.5 Nissan before that was bit jumpy on start but had no power after the acceleration so I want to make sure it is not the after-effect of that car.
I plan to do 3x3 trans. flush and rear differential flush since I don't know if it was done - but not sure if this gear ratios I experience are normal for Acura RL... anyone had similar experience? Thanks all!
Factory Specs state:
First Gear Ratio (:1): 2.70
Second Gear Ratio (:1): 1.57
Third Gear Ratio (:1): 1.07
Fourth Gear Ratio (:1): 0.69
Fifth Gear Ratio (:1): 0.48
Old Jul 15, 2011 | 12:02 AM
oo7spy's Avatar
Sounds completely normal to me. However, I usually shift at 4000 rpm. This car picks up after that, and VTEC engages at 4950 RPMs.
Old Jul 15, 2011 | 06:59 AM
HEAVY_RL's Avatar
Nissans are low RPM, all torque, gas guzzlers... no comparison IMO to Honda...
With that said, I think yours is fine... turn the radio up and ride.
Old Jul 15, 2011 | 07:28 AM
rlx015's Avatar
I already feel better - thank you All!
Old Jul 15, 2011 | 04:37 PM
getakey's Avatar
VTEC does not engage until 4950?
Feels like it engages around 3500 - or is that something else at work
Old Jul 15, 2011 | 04:47 PM
getakey's Avatar
I guess I should have searched
There is something happening at 3500, but it is not VTEC just like you said
https://acurazine.com/forums/2g-rl-2005-2012-76/vtec-engagement-point-question-750275/
Old Jul 15, 2011 | 04:56 PM
Ken1997TL's Avatar
Variable intake
Old Jul 15, 2011 | 06:43 PM
EL19's Avatar
Variable intake
the intake goes from half volume capacity usage to full volume capcity usage at 3500rpms. Its a great thing. Helps improve low end torque and high end horsepower along with vtec.
Old Jul 15, 2011 | 07:41 PM
rlx015's Avatar
This is good stuff to know... I wondered how is possible that non stop I feel torque under the pedal and I am not even trying - luv it!
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
Sep 15, 2015 06:44 PM
datadr
Sep 12, 2015 09:12 PM
