Fog light pattern
Old Aug 28, 2013 | 08:19 PM
Sniffles's Avatar
Fog light pattern
Has anyone else noticed that the light pattern from the fog lights doesn't match on the floor? My driver and passenger side aren't symmetrical. Driver side light output on the floor is closer while the passenger side light output on the floor is further out. Idk why its not shining the same distance on the floor. Any ideas? Thanks
Old Aug 28, 2013 | 08:33 PM
sj993's Avatar
You can adjust the level of the fog lights. If you look directly underneath the fog light, inside the opening of the bumper (the air vent slots) there is a small slot where you can put a phillips screwdriver in to adjust the level.
Old Aug 28, 2013 | 09:22 PM
oo7spy's Avatar
Are your bulbs seated correctly? Are your heat shields identical in shape and position?
Old Aug 28, 2013 | 09:35 PM
HEAVY_RL's Avatar
to many variables.
Old Aug 28, 2013 | 10:23 PM
Sniffles's Avatar
I tried adjusting it but the screw on the passenger side just keeps turning after awhile with no leveling. The only difference is the driver side assembly was replaced new and passenger side has never been replaced...driver side's pattern looks normal and the passenger side looks off. The bulbs I put in locked in for sure. However, when looking in from the lens, the driver side's led bulb and passengers bulb aren't in the same. Driver side is mounted visually vertically while the passenger side is horizontally...even tho I tried to install it matching if it makes sense. The passenger only installed one way so idk why they locked in a bit different. Trying to avoid a new fog light assembly cause that's the only thing I can think of....lol
Old Aug 29, 2013 | 08:27 AM
oo7spy's Avatar
Why does it matter again?
Old Aug 29, 2013 | 11:15 AM
Carbon Legend's Avatar
That is your problem is the bulb position. bulbs are suppose to go in vertically up and down to direct light out. when bulb is mounted horizontally it creates dead spots in light.
Also what kind of bulbs are they? good quality or some ebay LED bulbs? i would go back to standard halogen bulbs if you are concerned about output.
Old Aug 29, 2013 | 11:36 AM
Sniffles's Avatar
Same concept if the low beams weren't matching...one way too high and the other normal.
Thanks, thats what I thought but I can't seem to get it installed vertically. Its a legit kit. The led is built with excellent quality and produces 1800 lumens. It should only go in one way so if its installed horizontally, I don't think getting it in vertically possible...wish I knew why lol
Old Aug 30, 2013 | 03:28 PM
oo7spy's Avatar
Link to the kit and pics?
Old Aug 31, 2013 | 07:10 AM
Sniffles's Avatar
http://www.vleds.com/bulb-type/drl-f...eadlights.html
I took them out because its not white. More like a 4300K even tho its rated 5K. However, the light output was pretty impressive for a led.
Old Aug 31, 2013 | 01:08 PM
i would inspect both of them and make sure your bulb base and LED's are in line if not call VLed and let them know what is up. they have good customer support and would replace it no problem
Old Aug 31, 2013 | 02:22 PM
Sniffles's Avatar
Its not the bulbs because this happened to a set of 3K Morimoto HID bulbs before...same issue. I'll check one last time when my 6K HID comes in. Thanks!
Old Aug 31, 2013 | 03:39 PM
is it a oem foglight that was replaced, or was it a aftermarket? its been a while since i had a stock foglight is it possible to install the light upside down?
Old Aug 31, 2013 | 04:35 PM
Sniffles's Avatar
The driver side was replaced oem and the passenger side was original. I highly doubt you can install upside down or any other ways since there's a bracket to mount it to the bumper..do you happen to have a passenger side laying around?
Old Aug 31, 2013 | 06:32 PM
nope i have retrofitted foglights since my oems were busted
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
