Feeler for Custom header made??
Old Apr 16, 2008 | 03:45 AM
  #41
aznbo187's Avatar
Originally Posted by supergreen
Found this in a press release for the 2006 RL. Some good info... but unfortunately it doesn't say where exactly the valve is located.
CLOSE-COUPLED CATALYZERS AND VARIABLE FLOW EXHAUST SYSTEM
The exhaust manifolds of the RL are cast directly into the alloy cylinder heads to reduce weight and to put the engine's two primary catalytic converters as close as possible to the combustion chambers. The 600-cell per-square-inch, high-efficiency converters mount directly to the exhaust port of each cylinder head for extremely rapid converter light off after the engine starts. By eliminating traditional exhaust header pipes, this arrangement results in a significant weight savings.
A hydroformed 2-into-1 collector pipe carries exhaust gases to a single 350 cell-per-inch secondary converter under the passenger cabin. To balance the engine's need for proper exhaust backpressure at low speed and free flow at high speed, the exhaust system incorporates a variable flow rate feature. An exhaust pressure-operated valve in the system has two operating modes. The low speed mode has a flow rate of 130 liters per second; when the engine reaches about 4000 rpm, the exhaust pressure rises enough to open the valve, which increases the flow to 150 liters per second.
I couldn't find any external hoses or solenoid units attached to the muffler, or the j-pipe. I want to say that it's probably just a tuned spring loaded flap inside the canister, that is set to open at a certain pressure.
If this is the case, it would be awesome because it would then still maintain a quiet ride when cruising, and at the same time it would work along with the true dual J-Pipe setup as it opens up the valve as more throttle is added.
We're getting closer!
1.fatty
2.supergreen
3.Roy Cya
4.2007AcuraRL
5.deepdezal
6 neuronbob
7.legendaryrl
8.bosco78
Old Apr 17, 2008 | 01:29 PM
  #42
supergreen's Avatar
Judging by the wording they use, it sounds like there is only one valve in the exhaust... which means unless it works like the 3000GT VR4 which used only one muffler for the "cruise" setting and both mufflers for the "sport" setting, it must be located either at the end of the j-pipe, or in the pipe directly after the cat before the exhaust splits again.
Maybe Bob or Roy (or anyone with an aftermarket exhaust) can help us to determine if this is the case.
Old Apr 18, 2008 | 07:12 AM
  #43
Roy Cya's Avatar
As far as I remember there was nothing before or after the cats. Unless the valve is mechanically driven, I dont think there is one.
Bob, do you have a better recollection?
Later,
Old Apr 19, 2008 | 09:41 PM
  #44
neuronbob's Avatar
Bump with results of TL J-pipe mod: 7 hp and 14 lb-ft .
https://acurazine.com/forums/audio-video-electronics-navigation-22/pioneer-navi-system-174509/
Sounds easy to install if the TL guys are correct.
Old Apr 23, 2008 | 09:06 PM
  #45
supergreen's Avatar
Thanks for the link Bob!
The torque numbers are quite impressive. Anyone that has ever complained about the lack of torque in the RL should take note.
Old May 8, 2008 | 12:11 AM
  #46
aznbo187's Avatar
Power for the win.
Old May 8, 2008 | 12:53 AM
  #47
AmBiGuOuS626's Avatar
Can't there be just 10 RLs to do this. = ) I'll jump in to be ninth RL and hopefully one more will come. It's going to be a VERY LONG time until we have 15 RLs who would want to do this Mod.
Old May 8, 2008 | 06:01 AM
  #48
///M Roadster's Avatar
Just to stay objective, what concerns me with these bolt on ideas is lack of custom tuning availability. When you slap on a Cold Air Intake and *if* it does allow the engine to suck more air, I assume long term fuel trim (LTFT) will stay higher to compensate. As long as power curve stays similar to stock, stock ECU tuning with higher LTFT should be able to make the car run well. Meaning, peak hp gained (more air to the engine), higher LTFT should provide enough fuel at the top safely. This is assuming stock ECU runs off of a set fuel map at wide open throttle like many other cars, including BMWs.
When you slap on headers, you could actually change the power curve. On a part throttle conditions, Short Term Fuel Trim (STFT) should compensate and make the car run safely in most conditions. But irregular changes in STFT across the power band (since power band could have been changed) may result in LTFT changes that we may or may not want. Meaning...at WOT, there could be unexpected fuel delivery at top. Which shouldn't be too dangerous to the engine unless it is running extremely lean, but just not ideal.
Is there custom tuners for these honda cars? (like in BMW side) Who can actually work on these honda ECUs? If there are that I do not know of...custom tuning availability + bolt-ons sounds much, much more enticing.
Old May 8, 2008 | 11:43 AM
  #49
aznbo187's Avatar
Good point!
The factory ECU does have several sensors (intake/exhaust) to detect an increase in air, telling it whether to run richer or leaner. Modifying the exhaust in a naturally aspirated setup, we are mainly looking to improve head scavenging, which allows a fresher and a larger intake charge to occupy the combustion chamber. This means more air is allowed to flow through the intake, which will be adjusted by the air flow sensor/meter. In cases where you have more aggressive modifications, a large increase over the factory range will limit your ECU, and also your engines capabilities, but a simple modification such as this or an intake should be within the factory ECU's range.
On another note, I did speak to JET performance, and they have a re-flash out for the RL for $329. They said they received gains of 14whp and 12tq on a stock RL. If you specify that you have an exhaust, or intake, they can tailor the flash more towards that as well.
Once we get more people on this, I'll contact them as well to see what they can do for us, as a group.
  #50
aznbo187's Avatar
It doesn't show up on their website for some reason, but the item part# is 65001.
Old May 8, 2008 | 06:44 PM
  #51
neuronbob's Avatar
Stop the presses. When did this happen? I'd LOVE to tune the ECU to fit my intake and exhaust. Where do I get it? I thought Amuse was the only company with an ECU for the RL, but there was no way to get it to the US.
Details, please.
EDIT: Found some. is my friend.
Part #65001
A similar product?
EDIT #2:
The Jet Performance site has dynos only for the RSX and a 2005 Integra. No RL. Someone would have to figure out ideal A/F ratios, then make a dyno.Jet Peformance dynos.
Old May 8, 2008 | 07:28 PM
  #52
LegendaryRL's Avatar
Ask them to figure in the pulley as well.
Old May 8, 2008 | 09:16 PM
  #53
aznbo187's Avatar
Details, please.
Part #65001
A similar product?
EDIT #2:
I just happened to check it when I was seeing if they had anything for the TL. No information showed up when I went to their site, but they had an application listed, so I just called in and the guy gave me the information.
The link does seem to be the same product, but the picture isn't. This is a reflash, meaning you send in your ECU, and they flash it, and send it back to you. Should be a great addition to the headers, intake, or exhaust.
Old May 8, 2008 | 11:06 PM
  #54
neuronbob's Avatar
Did they tell you whether they had an actual RL dyno with gains? Those of us with intake and exhaust really need this product for ideal tuning.
I ask only because without this information, we'd have to experiment with ideal settings on our own.
Old May 14, 2008 | 12:21 AM
  #55
aznbo187's Avatar
They did say that they had an actual RL that they brought in to R&D.
As far as setting it for your own, it's not a tune-able chip. Meaning they flash it once, and that's what it stays at until you send it back to them to reflash it. Best thing to do is to get all your bolt ons figured out, and then send it in with that in mind. I believe most people will stick with the basic Intake, J-Pipe (hearder), and exhaust.
Old May 14, 2008 | 05:11 AM
  #56
neuronbob's Avatar
Thanks. i still wish they'd done a dyno, though. That'd make it easier to decide whether the product was worth buying.
Also, bump.......c'mon, where are the modders at?
Old May 14, 2008 | 11:05 AM
  #57
IamLegend's Avatar
Put me down on that list. I'm posting from my iPhone so I can't cut and paste the list. #10
Old May 15, 2008 | 02:26 AM
  #58
aznbo187's Avatar
1.fatty
2.supergreen
3.Roy Cya
4.2007AcuraRL
5.deepdezal
6 neuronbob
7.legendaryrl
8.bosco78
9.AmBiGuOuS626
10.iamlegend
Old May 29, 2008 | 11:15 PM
  #59
BUMP!!!
Just need FIVE more RLs guys!!!
Old Jun 9, 2008 | 02:24 AM
  #60
aznbo187's Avatar
RL Lovers.
Old Jun 20, 2008 | 12:08 AM
  #61
sportyshortee's Avatar
Hi members, let me first say that you guys run a top notch site and the members are top notch also. I've been logging on for a while and just checking information that has been a great help to me. Haven't posted much but love the info and I really trust you guys. (got a 2001 acura cl) With that said I'm picking up my preowned rl this coming week and I would be totally interested in the mods. So if possible put me down please. Will post pics and avatar when I pick up my car. (I'm a police officer and I am always working.)
Old Jun 20, 2008 | 12:45 AM
  #62
fatty's Avatar
congrats and welcome!
1.fatty
2.supergreen
3.Roy Cya
4.2007AcuraRL
5.deepdezal
6 neuronbob
7.legendaryrl
8.bosco78
9.AmBiGuOuS626
10.iamlegend
11.sportyshortee
FOUR MORE!
Old Jun 20, 2008 | 07:51 AM
  #63
2007AcuraRL's Avatar
Its been so long since this thread started that the number of takers on the list may not be accurate any more. The magic number could be more than four if some have lost interest....
Old Jun 20, 2008 | 08:30 PM
  #64
fredren's Avatar
unofficial HONDA rep
hey guys count me i n
Old Jun 21, 2008 | 12:03 AM
  #65
fatty's Avatar
1.fatty
2.supergreen
3.Roy Cya
4.2007AcuraRL
5.deepdezal
6 neuronbob
7.legendaryrl
8.bosco78
9.AmBiGuOuS626
10.iamlegend
11.sportyshortee
12.fredren
Old Jun 21, 2008 | 07:37 AM
  #66
bosco78's Avatar
9th Gear
I'm still in
Bosco78
Old Jun 21, 2008 | 12:22 PM
  #67
neuronbob's Avatar
I'm still in, too.
If the list is accurate, only three more to go.
C'mon, guys!
Where tha' modders at?
Old Jun 21, 2008 | 07:30 PM
  #68
Roy Cya's Avatar
I'm in as well!! C'mon y'all!!!!!
Waddup?!
Old Jun 22, 2008 | 11:57 PM
  #69
IamLegend's Avatar
I'm still in and waiting. Let's make this happen
Old Jun 23, 2008 | 03:12 PM
  #70
neuronbob's Avatar
TTT
So we can finally get this going. We are SO close....
Old Jun 25, 2008 | 06:38 PM
  #71
andysdesign3's Avatar
angel eye RL
hey boys..i wanna get in...pm me
Old Jun 26, 2008 | 01:12 AM
  #72
aznbo187's Avatar
1.fatty
2.supergreen
3.Roy Cya
4.2007AcuraRL
5.deepdezal
6 neuronbob
7.legendaryrl
8.bosco78
9.AmBiGuOuS626
10.iamlegend
11.sportyshortee
12.fredren
13.andysdesign3
Old Jul 1, 2008 | 08:34 AM
  #73
fredren's Avatar
1.fatty
2.supergreen
3.Roy Cya
4.2007AcuraRL
5.deepdezal
6 neuronbob
7.legendaryrl
8.bosco78
9.AmBiGuOuS626
10.iamlegend
11.sportyshortee
12.fredren
13.andysdesign3
come on guys only 2 more people needed.
Old Jul 2, 2008 | 06:52 AM
  #74
mandkcasey's Avatar
Hey everyone, I came across this thread and registered right away. I will be picking up my RL within the next week so please put me on the list. I work part time for a performance shop in the Chicagoland area and we have an AWD dyno. So I plan on some before and after dyno numbers if you guys can make this. Thanks, Mike
Old Jul 2, 2008 | 07:12 AM
  #75
mandkcasey's Avatar
I will have to call A-PEXi. They specialize in a lot of Honda/Acura tuning and they have controllers with specific VTEC functionalities.
There is the NEO, but you usually have to hack the main harness.
http://www.apexi-usa.com/product_ele...=260&pageNum=1
Then they have ther're newer unit which flashes the ECU and also has the VTEC functionality.
http://www.apexi-usa.com/product_ele...=197&pageNum=1
Old Jul 2, 2008 | 07:41 AM
  #76
fredren's Avatar
1.fatty
2.supergreen
3.Roy Cya
4.2007AcuraRL
5.deepdezal
6 neuronbob
7.legendaryrl
8.bosco78
9.AmBiGuOuS626
10.iamlegend
11.sportyshortee
12.fredren
13.andysdesign3
14.mandkcasey
1 more, just 1 more..
Old Jul 2, 2008 | 09:23 AM
  #77
neuronbob's Avatar
So close......so close......
Old Jul 2, 2008 | 07:03 PM
  #78
MrHeeltoe's Avatar
Former Sponsor
Go mike go!!
Old Jul 8, 2008 | 01:50 PM
  #79
supergreen's Avatar
Only one more!
It's about time to break out the socket wrenches and TIG welder!
Old Jul 9, 2008 | 02:10 AM
  #80
csmeance's Avatar
[QUOTE=fredren]1.fatty
2.supergreen
3.Roy Cya
4.2007AcuraRL
5.deepdezal
6 neuronbob
7.legendaryrl
8.bosco78
9.AmBiGuOuS626
10.iamlegend
11.sportyshortee
12.fredren
13.andysdesign3
14.mandkcasey
15.csmeance
I'll be honest, i'm interested in it, and would get it as soon as I get my RL, but i may not buy it as I still have to work out the details on either an 09 or 08 RL. Also will it fit the 09RL, I don't have a chance right now, but the part numbers for the 09 to the 08 RL should say so.
