Does anyone use their parking brake?
I absolutely despise footwell-placed parking brake pedals and loved having the handbrake next to me in my 3G TL. As a result, I have not been using the parking brake except on hills--I just can't make myself use it. I understand the ergonomic reasons for placing the parking brake in the footwell, but I learned to drive with a manual and I just feel better with a handbrake. It's one of a very few, miniscule issues I have with my RL.
Do you guys use yours, and is there a good reason for using it? I'm just curious.
I agree with you Bob. The handbrake should not be located in that spot. It's too suv or minivanish imho. I never use it either except when I'm parked on a hill, which is rare.
I always use the parking brake to protect the transmission pawl. If you do it automatically, you do not have to worry about whether you are on a hill, however slight. It becomes like using a seatbelt, almost automatic.
I use it even when I park in my garage. All of the cars in our stable have a foot brake, though, so I'm pretty well trained.
I feel that a handbrake seems a little out of place in a luxury-minded car with an automatic transmission. A manual tranny should always have a handbrake.
Rob144
Rob144
Always use mine. Mostly because I do it out of habbit (like clicking my seatbelt). My old Lexus had a foot break... but a very ergonomically placed hand-held release. My Volvo had a hand break. My wife's Sienna and the RL now both have the same foot break. I do notice that I don't usually press it down hard enough to have it prevent some minor wheel roll and transmission grab.
I for one like the placement of the parking brake pedal. Just like the post above, it's very unsightly for a luxury car to have that handle in the middle of the shifter area, another place where dust will accumulate and difficult to clean. With the RL having a pedal just made it easier to put it on and take it off, not a lot of extra movement. I'm not lazy or anything but that's how a luxury car should be, pampering you all the time you're inside.
Registered TL Owner
We never used the parking break on the G35 or my dad's old avalanche either.
Go Big Blue!
To answer your implied question; If I had a manual Trans, I'd prefer a handbrake and would sacrifice loosing the storage space up top. However, I think it's a wise move to set it as a foot pedal on the RL.
Always use your parking brake. As stated above, it protects the transmission pawl. Although the pawl locks the transmission it is not meant to hold the cars weight in anything but a completely flat surface.
What is a pawl?
I guess I'll try to use it more, but really don't like to. Half the time I forget it until I've shifted the tranny to "D". The handbrake provides a visual reminder to use the parking brake and in my TL I used it every time I parked.
I park on an inclined driveway every day, and I never use the parking brake. Pointless, I think, on an automatic car. Yeah, OK, the parking pawl (and that's what it's called) might have some additional wear on it over the years, but I think unless you slam the tranny in "P" while the car's moving, it'll be just fine.
There's little enough space in the center console (why, I don't know, but it's totally cramped) to have to fit in a handbrake lever, too.
EDIT: Bob, the pawl is the device that engages a sprocket in the transmission's output shaft when you put the car in "P". It's a little lever with a tooth on it that holds the sprocket from moving. http://en.wikipedia.org/wiki/Ratchet_%28device%29
Go Big Blue!
If/when I'm on a sharp incline I would use the parking break. if for no other reason, it makes shifting out of park later on easier. Also, it just feels like a good thing to do for safety reasons in case the tranny "pawl" decides to give way. However, I totally agree, on level (or near level) ground. It can't possibly matter
2012 Cadillac CTS-V Coupe
What is a pawl?
Aside from the red light on the dash, the message "DRL OFF" appears on the MID(assuming the headlights aren't on) when the parking brake is on.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
That's right, I don't look at those right after I jump into the car and start it. Seriously. It just isn't part of my "pre-flight checklist" as I have been used to seeing a handbrake. Well, like I said, I guess I'll just have to get used to it. It's the last adjustment I have to make to my RL.
What is a pawl?
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
The pawl is a part in the tranny that locks the gears when you put the car in park. It does lock the tranny and keeps the car in place, however, the transmission gears are not "meant" to hold the car's weight while its standing still. On a steep incline the pawl might just let go (as we read in the paper of empty runaway cars every day), but more insidiously, it damages the gear bearings. Bearings are happiest when rotating rather than when simply bearing a static weight. As some have already posted here the risk of bearing damage is small, the risk of it running away while in park on a hill is much more common and problematic. As I already posted previously, its really not an issue on flat or almost flat surfaces, but on an incline of more than 15 degrees or so you are looking for trouble. I had a buddy that had his accord go down the hill into his neighbor's property TWICE!!!! the second time it actually ended suspended in a tree. His never forgotten since ![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
White and Nerdy
In Pittsburgh, my theory is that anything that helps prevent your car from sliding down the hill helps, so, yes, I use the parking break.
I actually like the parking brake in pedal form, but wish it was like my dad's old Cadillac, which would deactivate the parking break when you shifted out of park. The pedal would snap back into the deactivated position.
Go Big Blue!
Originally Posted by medrxman
Not only does using the parking brake protect the transmission pawl, it also adjusts the rear brakes. Not using the parking brake will eventually cause the rear brake adjuster to become inoperative. USE MINE MOST OF THE TIME
Unless there is something special about the Acura, there is no causal link between the pad wear adjustment function (which is what I'm assuming he is talking about here) and the e-brake. Disclaimer: most of my experience is with Toyotas, but I'll go out on a limb and say the mechanism is not that far removed on an Acura.
Maybe in the days of drum brakes... but rear disc brakes with floating calipers don't need adjustment....
There's an adjustment on the parking brake cable that self-adjusts to follow the wear of the brake pads, but again, I can't see that needing any kind of adjustment, either.
Originally Posted by SpicyMikey
That's one I've never heard before. No offense to medrxman, but can anyone else confirm that? I live in South Orange County, FL, which is as flat as flat can be. I never use my parking brake any more.
"Using the parking brake helps keep the cables freed up so corrosion can't buildup and cause the cables to bind. Applying the parking brake also works the self-adjusters in the rear brakes and helps keep the linings in drum brakes properly adjusted for minimum pedal travel. On cars with four wheel disc brakes and locking rear calipers, using the parking brake keeps the threaded self-adjusting mechanisms inside the rear caliper pistons working freely to compensate for pad wear."
Yes, I agree it was drum brakes, however it appears best to use the E-Brake as indicated.
Link below for article:
http://www.aa1car.com/library/2003/bf40358.htm
'05 RL 300K Miles
I do a fair amount of surveillance for work. So at night or any other time I don't want my running lights on, I set the parking brake, turn the car off, re-start it, voila, no running lights. Now if I could only get a cloaking device....
always use the parking brake on inclines to help the transmission. i have used both hand brake and foot brake and now they are both second nature to me. just remember if your foot brake was a handbrake, then the center console would be more crowded and less storage space.
Go Big Blue!
AcurAdmirer
Living as I do in fairly flat north Texas, I use the parking brake only when I'm parked on an incline.
But I have to agree with those who feel a handbrake sticking up beside the seat is both unsightly and out of place on a luxury sedan with AT. The only change I'd make is a release on the dash (or even an automatic one when shifting out of "P"). I have always found the "push to engage and push to release" system a little awkward.
AcurAdmirer
This morning, like a duma$$, I started driving the car with the parking brake engaged. Luckily, the bells started ringing immediately and I disengaged after a second or two.
I like your second suggestion better--automatic disengagement when shifting out of "P". This morning, like a duma$$, I started driving the car with the parking brake engaged. Luckily, the bells started ringing immediately and I disengaged after a second or two.
My old Cadillac STS had that feature -- a foot mounted brake which disengaged electrically when you shifted out of Park.
The one and only time I used it, the spring loaded thing went off when I shifted out of park, and it wailed me in the shin. That was it for the parking brake, it freakin' HURT.
I guess, like the cobbler's son having no shoes, knowing a lot about the workings of the brain gives you no leg up on using it. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
It's just so hard to overcome old habits.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
2014 SH Advance/2006 Tech
Dont use
I really dont use the E-brake. I know that it helps in protecting the Tranny. I use it for my other Car Civic Hybrid though. I really didn't like the brake position.But I will use for sure in incline.
lanechanger
10-13-2015 10:56 AM
