Cooling fans broken
Old Sep 24, 2015 | 02:23 PM
juanrl's Avatar
9th Gear
Cooling fans broken
Hello everyone 😀i really need some help here my rl has both of the fans broken, so o ordered them at the dealership, but now the mechanic says that i needs the fan motors too, because the motor was the cause why the fans broke. My question is, do i really need the fan motors or he just want to meke more cash.I sincerely appreciate your help, thanks.
Old Sep 24, 2015 | 02:28 PM
the fan needs a motor to spin.
if the old fans werent spinning, MAYBE the fan motors are bad.
Old Sep 24, 2015 | 02:43 PM
juanrl's Avatar
9th Gear
Thanks for that quick response juntnspace, yes the fans were working or spinning before, í already ask another mecanic and they don't even check the motor, thai just said that í need the fan motor too.
I guess I'm gonna have to spend $550 for those motors.
oo7spy's Avatar
The motors are powered by the 50A fuse on the positive battery terminal connector. Make sure that isn't blown first.
Old Sep 24, 2015 | 02:44 PM
so, if they were spinning, why replace them ?
like, 007spy mentioned check the fuse first!
Old Sep 24, 2015 | 03:08 PM
juanrl's Avatar
9th Gear
Thanks oo7soy, o will check that as soon as ó get home.
Old Sep 24, 2015 | 03:17 PM
juanrl's Avatar
9th Gear
this new mechanic told me that the reason the fan blade broke from the center is because the there's something wrong with the motor, he said the motor would be wobbling from the part holds the fan blade.
Old Sep 24, 2015 | 03:18 PM
Hmm if the fan is broken..
Then I guess you should get a new juan.
Old Sep 24, 2015 | 10:04 PM
stevieray's Avatar
2007 LSM KB1 Tech w/CMBS
If both fans stopped, that's not the motors. That would be a one in a million that both motors would burn out. Also extremely rare that a fan would come loose from the motor. I personally think your mechanic doesn't know shit about Acuras and is just guessing. Check the fuse first and then both fan relays in the underhood fuse box. Not sure about RLs but Legends had a fan timer switch that if it went bad, both the condenser and radiator fans would quit working. In any case, DO NOT LET THE CAR OVERHEAT!
I sure wish people would spend the $80 for a HELM Factory Service Manual for any Honda. I have never bought a Honda and not gotten the FSM. It has allowed me to troubleshoot problems like this and saved a ton of $$$.
Old Sep 29, 2015 | 03:25 AM
juanrl's Avatar
9th Gear
Problem solved
The mechanic was right,Fan motorbushings are worn out, causing the fan to wobble when it spin, and eventually break the fan
So I just got new fan motors, thanks again for your help.
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
SexyRL
4G TL Problems & Fixes
Aug 19, 2016 10:03 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
hashbrown
Sep 29, 2015 12:13 PM
dirleton
Sep 29, 2015 08:26 AM
