Anyone install OEM mudflaps themselves?
Old Nov 30, 2006 | 04:26 PM
jcb-memphis's Avatar
Question Anyone install OEM mudflaps themselves?
Hi.
Is it difficult to install the mudflaps. Looking at the wheel wells, it looks like three screens and that is it. ....
Something tells me it is not "that" easy. Is it?
TIA
JB
Old Nov 30, 2006 | 04:35 PM
phins2rt's Avatar
Originally Posted by jcb-memphis
Hi.
TIA
JB
yep, looks like just three screws....
https://hondacuraworld.hostasaurus.c...05rlsplash.pdf
Old Nov 30, 2006 | 05:30 PM
Wow..thanks. 30 minutes and a pdf installation guide. Amazing.
Again, thank you very much!
Great forum.
JB
Old Nov 30, 2006 | 07:08 PM
phins2rt's Avatar
Great forum.
JB
No problem. Good luck with the install even though you shouldn't need it!
Old Nov 30, 2006 | 07:13 PM
vluu's Avatar
I just installed my OEM mudguards last night. Took me about an hour. The front one's are easy, but you will need to turn your steering wheel side to side so that you can use a screw driver to fasten the screws. The front screws are already installed when you buy the car.
The rear flaps are a bit harder b/c you don't have as much room since the rear wheels are not movable. You will need a small short screw driver. I just happen to have one, made it easier. When you buy them, they provide you 4 screws and 4 clips. 2 of them each for the rear mudguards. The 3rd screw in the rear is already screwed in, so you will have remove it first before installing the rear flaps.
I'm happy with my results, plus it will help with the dirt getting on the bumpers and under carriage.
Good luck!
Old Dec 1, 2006 | 06:40 PM
kollamala's Avatar
installation of mud flap
I found that a small ratchet screw driver( at right angles) really helped when I installed mine. it took me 1 hour to install it. Back ones were hard because of the access.
Old Dec 5, 2006 | 07:29 PM
txlazer's Avatar
it's a cake walk
Hi.
TIA
JB
it's a cake walk, it is easier to do the rear IF you remove the tires BUT you don't HAVE too.
Gregg
Old Dec 9, 2006 | 01:14 AM
Gregg
Got them today. Had a ratchet screwdriver from Home Depot (small).....40 minutes. Thanks all.
JB
comptech
Gregg
JB
HairyMonkey019
Apr 22, 2016 10:50 PM
bailey24
Nov 21, 2015 08:43 PM
nanos
Nov 12, 2015 08:41 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
MyKids&Cars
Sep 1, 2015 12:53 PM
