2G RL A/C Problems
Old Dec 27, 2016 | 09:32 PM
  #241
alfadoctor's Avatar
Originally Posted by alfadoctor
THank you for your advice. I wias thinking of taking it in and having someone listen and see if it was what I think it is. A new compressor is $325 plus the labor to install and recharge it.
Now that I replaced the power belt, tensioner, the problem is still there. I erred on the caution side and guessed wrong. What the issue is the power steering pump. When you move it off center in either direction it chirps. Even when holding it in a constant turn, and then moving the steering wheel, it chirps. If you hold the wheel just right you can feel impluses from the pump. So problem resolved but it wasn't related to the a/c. Now to find the threads on the power steering pump.
Old Dec 27, 2016 | 09:52 PM
  #242
oo7spy's Avatar
If there are leaks, you can rebuild: https://acurazine.com/forums/3g-tl-p.../#post13413602
If there aren't, just replace it with one from a parts store. If you've replaced the serpentine belt, there is nothing special about replacing the power steering pump.
NBP_BALLER
Apr 1, 2017 10:50 AM
SoL_TeK
Feb 4, 2017 07:04 PM
Carbon Legend
Nov 25, 2016 01:50 AM
aceyatc
Nov 14, 2016 02:33 PM
Skirmich
1/2G MDX (2001-2013)
Oct 10, 2016 05:45 PM
