2012 RL Maintenance ?s
Old Apr 23, 2015 | 08:44 PM
stagefoursurvivor's Avatar
OK
Picking it up tomorrow, intend to add splash guards, all weather mats & trunk tray.
What should be checked/changed relatively soon?
Dinosaur oil for sure
Brake fluid change?
Tranny flush?
Tires? I've had MXMs before and consider them just adequate but, don't want to alter the SH-AWD dynamics
Can/should AcuraLink be updated?
Any and all suggestions appreciated.
I'm somewhat anxious because it's the first used car I've purchased in 30+ years and don't want to overlook anything
Old Apr 23, 2015 | 08:54 PM
CadiGTi's Avatar
2020 Acura RLX Advance
Front and Rear differential fluid s/b changed for sure on the RL. Part of the required maintenance. Have the battery checked too, the RL's usually eat them every 3-4 years.
Old Apr 23, 2015 | 10:05 PM
RLifer's Avatar
Congrats. I purchased a 2011 with Tech last august with 77k miles and just changed the oil. It had been maintained well and everything done according to MID. I changed the tires to Michelin Premier A/S. Added new floor mats, trunk tray, window tint 35% to follow state law, interior LED lights, LED license plate lights, LED reverse lights, now working on getting LED DRL's. Next goal is to get new wheels and summer tires.
It is a great car and I have learned a TON from this site. It has been a lot of fun knocking out each little project.
Old Apr 23, 2015 | 10:44 PM
oo7spy's Avatar
It's a Honda. Don't over think this, trust the engineers and follow the mid. Oil is typically 7k miles. Change your tires when they get to 2/32-3/32. The car will tell you when it's time for tranny and differential changes (oil too, I was just giving a heads up earlier). If you follow the MID, this car will last to half a million miles or 20 years, whichever comes first.
Old Apr 24, 2015 | 07:10 AM
I'm not gonna get carried away with any changes. Thought about the trunk spoiler but, it doesn't "do anything" for me, almost invisible IMO.
Unless I get one of those "rice burner" type that sit 1 1/2' above the trunk. My DW would love that! j/k
What about AcuraLink update or subscription? Don't recall how it was with the TL and, again, DWs car so I didn't drive it much. I do recall that the MB system in our E350 sucked..."make a left turn in 500 feet" on a 6 lane divided interstate highway!
Old Apr 24, 2015 | 07:27 AM
oo7spy's Avatar
AcuraLink doesn't have anything to do with the navigation. It connects the car to your cellular device and allows the car and dealer to send information back and forth. If your question is about upgrading the navigation disc, they provide the areas that change with every update. If your area wasn't updated in the last 3 discs, then there is very little use in upgrading.
Old Apr 24, 2015 | 07:42 AM
Huh?
I thought it provided "realtime" traffic and weather?
Old Apr 24, 2015 | 10:28 AM
oo7spy's Avatar
I think you are thinking of XM Satellite Radio. I don't know if the MMC was updated, but the 2005-2008 traffic is worthless according to many members here. There is a 30 min delay or so. Traffic that just happened won't help, and traffic that has already cleared may still show up. For the weather, there are two members with MMCs here who say that you can't turn it off. It takes over the screen and tries to talk to you weather you like it or not. (Pun intended.)
Weather issue: https://acurazine.com/forums/audio-b...isable-926265/
Old Apr 24, 2015 | 10:50 AM
RLifer's Avatar
Forgot to mention above, I just replaced front/rear rotors, brakepads(metallic in front, ceramic in rear), and stainless steel brake lines; all from stoptech(centric) from XLR8 for 1k total parts and labor; at mileage 82k on RL.
Plan on doing KYB shocks and struts this summer.
Old Apr 24, 2015 | 07:19 PM
I'm not "up to speed" on any aftermarket gear for the RL and since it's the DW wheels I likely won't pursue much.
I'll wait and see for now but, new tires are a priority. I've been happy with several renditions of Sport A/S, might go that way for the RL.
I've "tinkered" with my V70 somewhat. Still considering Bilsteins
Old Apr 24, 2015 | 10:15 PM
oo7spy's Avatar
KYB are the cheapest option to replace struts/shocks. There is no "mod" component to using them. The RL is a heavy pig and is known to cause strut failure after being lifted. I venture to say every RL between 70-100k miles could use new struts.
Obviously, brakes must be changed, and Acura OEM premiums aren't necessarily desirable.
Old Apr 25, 2015 | 05:39 AM
What do you mean by "lifted"? I have heard Bilsteins can be "harsh", don't think I'd want that on the RL?
What are the best brakes? Rotors? Without getting crazy
Old Apr 25, 2015 | 08:12 AM
oo7spy's Avatar
When you put the car on a lift or a jack, the struts expand, and an internal plastic seal can tear or dislodge (don't remember which). The MMC suspension does use different struts and shocks, so it's possible that they fixed that issue.
There is no "best" brake. There are lots of options for lots of different prices. XLR8, our board sponsor excelerateperformance.com, has a very reasonably prices set.
Old Apr 25, 2015 | 09:15 AM
How do you check the struts for this defect?
Old Apr 25, 2015 | 06:03 PM
oo7spy's Avatar
I don't think you can. When it goes completely and you go over a bump, you will know.
quanaman
Jan 9, 2023 07:33 PM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
ripit
Sep 26, 2015 06:19 PM
