09 Center console backward compatible?
Old Nov 20, 2008 | 10:53 PM
470hpGS400's Avatar
The 12v plug is on the the other side, but aside from that does anyone know if the dimensions are the same? Nice to have a matching wood center console.
Old Nov 21, 2008 | 03:36 AM
eVTEC's Avatar
I just finished my project with the 09 wood console on my 07 RL. You will need to modify to make it fit.
Old Nov 21, 2008 | 06:53 AM
CFoote's Avatar
If you don't mind my asking what did it cost you in parts? I assume you had to replace the shift gate underneath the shift bezel?
Chris
Old Nov 21, 2008 | 08:52 AM
Roy Cya's Avatar
You KNOW what I'm going to say, right?????
Sorry couldn't help my self!
Later,
Old Nov 21, 2008 | 11:28 AM
470hpGS400's Avatar
yes,pics and more detail please
Old Nov 21, 2008 | 04:17 PM
neuronbob's Avatar
Yeah, you know you don't just come up here and say "mod it" and NOT provide pics.
Old Nov 21, 2008 | 05:04 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
And how does it hold up with fingerprints and smudges? I can take it or leave it, but when I saw it at the auto show the 1st thing I saw when I opened the door was smears and fingerprints.
As it is I keep a microfiber cloth in the drink holder bin for stoplight dusting.
This might drive me over the edge.
Old Nov 21, 2008 | 05:11 PM
UW RL's Avatar
The Doctor
I thought I was the only one that keeps a microfiber in the car for stoplight buffing/dusting. TampaRL, it's good to have someone that's like me!
Old Nov 21, 2008 | 05:21 PM
Doc....we are a special breed.
And don't let him fool ya.... Chas is NOT one of us! Have you ever seen the dust on his dash!???
*ducking*
Old Nov 21, 2008 | 07:05 PM
eVTEC's Avatar
Later,
Cool with that?
Old Nov 21, 2008 | 07:10 PM
eVTEC's Avatar
The cup holder is direct replacement.
But the problem is really the center console piece, in which I need to cut and trim some parts to make the 12V fit. However, I did not connect the power to it because it will jam the movement for now. I will have to modify the socket to shorter one.
Old Nov 21, 2008 | 10:09 PM
Blazing GT's Avatar
looks really clean.
Old Nov 21, 2008 | 11:01 PM
Storm982's Avatar
how much did that part cost???
Old Nov 21, 2008 | 11:13 PM
470hpGS400's Avatar
Appears very doable for sure. Thanks for sharing.
Old Nov 21, 2008 | 11:22 PM
Rob144's Avatar
*ducking*
I better join the club....I keep my microfiber cloth under the driver's seat and a dust bristle brush in the armrest. Great for stoplight dusting of the console and steering wheel controls.
I've been tempted by the 2009 console, but the switched accessory plug has me concerned. I wonder if the JDM model still has the plug on the passenger side.....
Rob144
Old Nov 22, 2008 | 01:25 AM
eVTEC's Avatar
Rob144
I checked the JDM website, and, unfortunately, all 2009 RL has the wood console switch on the left side.
http://www.honda.co.jp/LEGEND/interior/
Old Nov 22, 2008 | 09:32 AM
2007AcuraRL's Avatar
eVTEC, can you tell why the console trim by the front of the silver shift gate appears to be raised up considerably? In the photo there appears to be a height difference of about the thickness of 2 quarters stacked on each other. It looks flush at the back part of the silver trim and then appears to raise up as it gets to the front....
Old Nov 22, 2008 | 09:41 AM
Part 77296-SJA-A43ZB PANEL ASSY., CENTER CONSOLE (ACC)
( DARK CURLY MAPLE ) list 194.22 discounted 155.38
Part 77230-SJA-J13ZB HOLDER ASSY., CUP
( DARK CURLY MAPLE ) list 251.31 discounted 201.05
Its parts #12 and #93 in the diagram.
Old Nov 22, 2008 | 10:26 AM
Blazing GT's Avatar
Question: I was at an Acura dealership looking at the 09 RL, The shifter is so nice and it flows well with the interior. What is the process in getting that swapped to our RL?
Old Nov 22, 2008 | 11:16 PM
eVTEC's Avatar
I went to LA Auto Show today and I checked two 2009 RLs. One of them has the raised trim on the front while another one has flush trim. I wonder if this is due to manufacturing toloerance?
Can someone go to dealership and check it out, too?
Old Nov 23, 2008 | 05:09 PM
Rob144's Avatar
Great investigative work. What do you suppose part 68 is in the picture? Is it the console for the 05-08? It appears to have the power socket on the passenger side.
Old Nov 23, 2008 | 07:09 PM
Originally Posted by rob144
great investigative work. What do you suppose part 68 is in the picture? Is it the console for the 05-08? It appears to have the power socket on the passenger side.
068 93903-32320 screw, tapping (3x12) 3 2009 rl
Old Nov 24, 2008 | 07:10 AM
CFoote's Avatar
Thanks for the information. Is the socket that won't fit the original one, or the new one? I was wondering if you could try the older socket or the new socket to see if it would help at all. Maybe you can't swap them, I haven't taken that piece out of my car yet.
For $350, that mod would be a cool one to have, much like the steering wheel and shift knob.
Chris
Old Nov 24, 2008 | 09:48 AM
470hpGS400's Avatar
As someone mentioned it above, my non wood RL has an uneven surface area around the shifter also so it is not just the wood enhancement.
Old Nov 24, 2008 | 10:32 AM
eVTEC's Avatar
Chris
The new socket is very different from the old. Even the mounting locations on the trim are different for the new socket. I did have to remove, cut and trim some parts in order to make them fit.
Old Nov 24, 2008 | 02:31 PM
CFoote's Avatar
It sounds like even some cutting + trimming did not help in getting the 12V socket to fit? Hmmmm. There must be a way. What is holding it up, the shift gate or wiring or ... ?
Chris
Old Nov 25, 2008 | 06:05 PM
nyjohnchan's Avatar
I think its easier to buy the wood trim pieces from ebay and just stick over it. Its quick, cheap, and will look good. My 2 cents.
Old Nov 25, 2008 | 07:12 PM
eVTEC's Avatar
When you're done with the eBay trim pieces mod, please take some pics and let us know.
Thanks.
Old Nov 25, 2008 | 07:18 PM
470hpGS400's Avatar
Used them in the past, never will again. The difference in quality and fitment is pronounced plus they have a very noticeable off color edge as they do not blend into the panel on the sides well. Pictures on Ebay will never how that angle of course , just the front face. They are much cheaper of course but I would be able to spot it from 10' away.
Some with less critical eyes may be pleased with them.
Old Nov 27, 2008 | 12:01 PM
MITIA's Avatar
eVTEC,
Please show pictures of what you had to cut and trim to make the 12V fit.
Old Dec 1, 2008 | 06:24 AM
CFoote's Avatar
Originally Posted by MITIA
eVTEC,
Last I heard he was working on making it fit, as he had to do some cutting...eVTEC, any luck yet?
Chris
Old Dec 1, 2008 | 10:04 AM
470hpGS400's Avatar
Difficult to judge from the pics, curious which wood tone is matches more, the steering wheel/shifter or the door trim as both two distinct tones to them. Given the proximity it matches the shifter. I prefer the older wood shifter to the newer leather one.
Old Dec 1, 2008 | 12:04 PM
fredren's Avatar
unofficial HONDA rep
besides for the center console anyone knows if the 09 dashboard black wood or whatever it's called and door panels inserts are compatible with ours? it would be nice to switch out the fake wood color for the black inserts..btu then i would also need the steering wheel and shift knob in addition to the dash and 4 doors..
Old Dec 1, 2008 | 12:11 PM
CFoote's Avatar
Probably about $2500 worth of parts there I would think....but sure it could be done.
Old Dec 1, 2008 | 12:50 PM
Ballinger's Avatar
When this gets all figured out by the pioneers, it would be great for one of you studs to lay out a parts list and DIY instructions. I noticed these wood elements in the '09 RL when I was at the dealership and was impressed: it really looks good.
Old Jan 1, 2009 | 08:01 PM
MITIA's Avatar
Don't expect any more info from eVTEC. He is to upset with me so he will be punishing all of us.
eVTEC message to me:
"I am not obligated to respond your message and since I did not get hold of computer since your message until yesterday, so much for your "courtesy". You probably could have just dropped me another PM asking if I got your message but you didn't.
I was planning to write something about the mod for the thread and I guess I won't do that after your "courteous" request."
eVTEC, I think you need to grow up.
Old Jan 1, 2009 | 08:39 PM
470hpGS400's Avatar
As someone that has posted countless mods on other forums (many of which were new to the market) I can say the responses (PMs) can be sometimes overwhelming and even a few that are a bit extreme from their belief it is their God given right to receive a timely and quick answer.
There is a certain amount of know how that each man should understand when coming of age and though everyone is on a different level of mechanical skills I am sure it does not take a whole lot in terms of being able to fit this the same as the OP has done.
Fit it, what does not fit, trim. I am looking at doing this in a month or so and will post up some detailed pics. Need to do the go fast stuff first this month.
Old Jan 2, 2009 | 01:23 PM
eVTEC's Avatar
Thumbs down
Well, thanks to 470hpGS400 for the comment. I just got back from my vacations and then I saw two new PMs from MITIA and the first was asking for the photo instruction, and then the second is his rude message saying I have no courtesy of replying him.
I think MITIA, you're the one who needs to grow up. Like I said earlier, nobody is obligated to reply to you, let alone take your rude comment. I am extremely surprised to see you yelling about me "punishing you guys" here about this minor issue.
It was a surprise to see this kind of nonsense from his PMs.
Here is the deal, I said it is a very easy mod and only needs some minor trimming of the console and the 12V outlet. It is easier than changing the headlight so I think you guys can definitely figure them out. Perhaps except for MITIA because he demands clear photo instructions.
Happy New Year.
Old Jan 2, 2009 | 02:22 PM
MITIA's Avatar
I just want to get record straight. I never demanded any information from anybody and I am going to leave as that.
Old Jan 2, 2009 | 04:43 PM
eVTEC's Avatar
MITIA, if you can be more patient it would help. Or your second PM could ask me if I received your first PM instead of "insulting" me like that. Why should you expect others to reply to you asap, especially during the holiday seasons?
In any case, I was away for vacation for quite a while and I am moving to a new place now so I have no time to take picture whatsoever. One of my heat switch's bulb is gone and if I replace it, i will take some pictures.
PS: I find it very hilarious for you to say I am going to punish the forum members by not posting the install instruction. Get a life man.
