Traction Control Issue?
When going around a corner in snow, without the brake applied, if the front end slips I sometimes experience a noise similar to the tire rubbing against the fender, or a sever grinding of gears that you might expect from the ABS system. Only, that is is much louder and less of a muted sound, and comes from the RF. It lasts less than a second.
Is this some sort of traction control system and could it be working improperly? If only happens on the right front side and doesn't have anything to do with the ABS system.
Has anyone else experienced this? Is this normal, or should I have it looked at?
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
Charlespsu
Sep 2, 2015 09:54 AM
