rear brakes - how many miles before replacing
Old Aug 29, 2019 | 10:56 AM
kipsy's Avatar
2016 rdx awd and awp , 40,500 mi, rear brakes, down to metal on one pad, other pad still has life.
also need tires soon, michelins have 5k left on them. I also use snow tires/wheels for 4 months a year, so maybe 30k on OEM michelins.
looking at Conti cross contact 25 (new model replacing the 20). , 70k mi warranty.
Old Aug 29, 2019 | 10:58 AM
replace them when they're worn.
dont go by miles...use visual intelligence...
if one is down to the metal, that would indicate a stuck or sticking caliper...use your eyes to determine what is happening, visual intelligence..
same thing with tires...if worn, replace.
Old Aug 29, 2019 | 04:25 PM
kipsy's Avatar
Just trying to see if others are getting more or less from the rear brake setup
Old Aug 29, 2019 | 05:11 PM
jcross1231's Avatar
Touring
Good to know. I haven't done brakes yet at 46,300 miles. Just replaced the tires with the same thing that was on it - Michelin MXM4's. The old ones probably had 5,000 left on them, but I've got a lot of driving to do in the next month.
Old Aug 30, 2019 | 04:27 PM
trcollins59's Avatar
2014 RDX, 91K miles, original rear breaks, front brake pads and rotors replaced at 78K miles.
Old Sep 3, 2019 | 09:45 AM
everyone drives differently, which means pads will wear differently...
let's say someone enjoys the thrill of stopping late...
or someone rides the brakes more...
those people will have worn out pads faster than say someone who doesnt do that stuff.
Visual intelligence.
Old Sep 17, 2019 | 11:03 PM
jjtoma's Avatar
4th Gear
Smile
2013 FWD front brakes at 91,000/ rear brakes at 141,000
it all depends on your driving style
Jim :-)
Old Oct 31, 2019 | 01:16 PM
zoomzoom24's Avatar
5th Gear
Had a similar issue, replaced the calliper along with new pads
Old Oct 31, 2019 | 02:26 PM
jjrphs's Avatar
Wife's 2013 AWD-TECH rear brake pads are ready for replacement now...95,000 miles. Replaced front brake pads and rotors at 71,000 miles
Old Oct 31, 2019 | 02:30 PM
zoomzoom24's Avatar
5th Gear
For the Front, did you use OEM parts or aftermarket ones? Can you share details? Mine are due soon.
Old Oct 31, 2019 | 02:56 PM
jjrphs's Avatar
I used Bosch BC1625 QuietCast Premium pads for the front and Bosch 26011548 QuietCast Premium Disc Brake Rotors. I like Bosch rotors because they're zinc plated...so the hats don't rust. I've also had great service with Centric rotors with powder-coated hats and Raybestos Professional Grade Ceramic Disc Brake Pads.
Good luck.
Old Oct 31, 2019 | 02:59 PM
zoomzoom24's Avatar
5th Gear
Good luck.
Thank you for sharing this
stanwelks
1G TSX Problems & Fixes
Jan 13, 2012 10:48 AM
Nyjumpman23
1G RDX (2007-2012)
Oct 27, 2009 06:44 PM
fishacura
Jun 19, 2009 08:07 AM
ltngbg99
1G RDX (2007-2012)
Jun 9, 2008 10:53 AM
eighteight
Apr 1, 2005 10:44 AM
