rear brakes - how many miles before replacing
2016 rdx awd and awp , 40,500 mi, rear brakes, down to metal on one pad, other pad still has life.
also need tires soon, michelins have 5k left on them. I also use snow tires/wheels for 4 months a year, so maybe 30k on OEM michelins. looking at Conti cross contact 25 (new model replacing the 20). , 70k mi warranty. |
replace them when they're worn.
dont go by miles...use visual intelligence...
if one is down to the metal, that would indicate a stuck or sticking caliper...use your eyes to determine what is happening, visual intelligence.. same thing with tires...if worn, replace. |
Just trying to see if others are getting more or less from the rear brake setup
Originally Posted by kipsy
(Post 16473198)
2014 RDX, 91K miles, original rear breaks, front brake pads and rotors replaced at 78K miles.
(Post 16473198)
let's say someone enjoys the thrill of stopping late... or someone rides the brakes more... those people will have worn out pads faster than say someone who doesnt do that stuff. Visual intelligence. |
2013 FWD front brakes at 91,000/ rear brakes at 141,000
it all depends on your driving style Jim :-) |
Had a similar issue, replaced the calliper along with new pads
Wife's 2013 AWD-TECH rear brake pads are ready for replacement now...95,000 miles. Replaced front brake pads and rotors at 71,000 miles
For the Front, did you use OEM parts or aftermarket ones? Can you share details? Mine are due soon.
Originally Posted by zoomzoom24
(Post 16499496)
Good luck. |
Originally Posted by jjrphs
(Post 16499517)
I used Bosch BC1625 QuietCast Premium pads for the front and Bosch 26011548 QuietCast Premium Disc Brake Rotors. I like Bosch rotors because they're zinc plated...so the hats don't rust. I've also had great service with Centric rotors with powder-coated hats and Raybestos Professional Grade Ceramic Disc Brake Pads.
Good luck. |
