Long Starter Cranking
Old Jun 11, 2025 | 08:58 PM
  #41
Alex Medeiros's Avatar
alexmed2002
Originally Posted by jetspeed
Did you ever change out the battery? If so did it work? Having this issue on a 2013 RDX base. Starts fine first thing in the morning, but gets progressively worse throughout the day. The longer it sits the worse it is. Battery is only a year old.
Get the battery tested thoroughly. Could be faulty.
Old Jun 12, 2025 | 10:52 AM
  #42
Tech's Avatar
Do you mean it starts fine first thing in the morning when the engine and engine compartment are cold?
And later on in the day when the engine and engine compartment are hot due to several trips during the day.
Old Jun 25, 2025 | 10:28 AM
  #43
jetspeed's Avatar
Correct
Old Jun 27, 2025 | 09:33 AM
  #44
Tech's Avatar
Correct
That is exactly the issue my friend with a 2005 Porsche 911 was experiencing. A normal start first thing of the day when the engine - engine compartment was COLD and then starts and non-starts as if the battery was nearly dead later on in the day when the engine - engine compartment was HOT.
He is not very technical and went on-line to Rennlist and grabbed what everybody thought it was, the cable going to the starter (a known issue) which is some cases would heat up at the "crimps", turn the copper blue due to high resistance and high current. I inspected the original starter cable which also went to the alternator and found nothing wrong with it, but he had already bought the expensive cable and wanted it installed (pain in the butt to install). Of course the cable wasn't the issue. Next came a battery which didn't solve the problem.
I believe in "diagnosis" instead of "guessing" aka being a "parts replacer" hoping the issue goes away if you throw enough parts at it. So the last thing he replaced was the "starter" and while he was doing that, I took the old one apart and found the issue. I have since rebuilt his old starter, fully cleaned it up and installed a new "brush plate".
This is what I found...No Start When The Starter & Engine Compartment Is HOT.
So I would suggest looking at all cable connections related to the battery and starter (cheap fix) and then look at the starter. You might want to do a current test of the starter when cold and when hot.
Old Sep 7, 2025 | 01:30 PM
  #45
mauricerdx's Avatar
5th Gear
Long start
It happened with me too
when I checked the battery voltage after I turned the engine off it was 11.0 volts , with the engine on 14.2 volts, I replaced the battery and no more starting delay.
acuraani
2G RDX Problems & Fixes
Feb 18, 2026 11:24 AM
NoMecanico
ILX Problems & Fixes
May 11, 2023 09:00 PM
mmhdavid
ILX
Jan 17, 2016 11:06 PM
Elli21486
1G TL Problems & Fixes
Jun 27, 2015 08:33 PM
dangtran09
Feb 16, 2014 12:38 PM
