Ignition start switch problem!
Old Mar 30, 2025 | 07:29 AM
viper111's Avatar
Hi guys,
I troubleshoot this issue since 2 weeks.
All interior equipment dead.
Ignition start switch problem:
1. Push and hold brake key fob near, push start, green LED blinking, no crank
2. Push and hold brake key fob on the start button green LED solid, engine starts after push
3. replaced both key fob batteries still the same issue
Could someone help me!
Viper111
Old Mar 30, 2025 | 08:24 AM
John from PA's Avatar
Have you ever replaced the 12v battery? I had similar behavior a few years ago with an Accord. Three different tests of the battery said it was fine. But these tests were done with the small hand held device like AutoZone and Advance uses for testing. When the battery was placed on a load tester it failed miserably when actually loaded. I would go to an old fashioned independent and have the battery tested.
The battery was replaced and I haven’t had any repeat issues.
Old Mar 30, 2025 | 08:38 AM
viper111's Avatar
The Battery is 2 months old don't think it is a battery issue!
Old Mar 30, 2025 | 09:00 AM
Agree. Do you have a voltmeter so you could check the voltage while charging (at a fast idle). Also, engine off battery voltage might be of interest.
Old Mar 30, 2025 | 01:48 PM
viper111's Avatar
Confusing! take battery off the engine while not running?
"Need voltage battery only" would be better!
Old Mar 30, 2025 | 01:52 PM
viper111's Avatar
13.2V low idle
12.8V Battery only
Old Mar 31, 2025 | 04:01 PM
viper111's Avatar
Where are you going with this?
Old Apr 1, 2025 | 02:23 PM
Just a rough check to confirm that the 12v battery is OK, and it appears by the voltages you’ve measured to be OK. Not much more to offer. Perhaps gather up the radio codes, etc. and disconnect the battery for afew hours to force a reset.
One other thing, I noticed you said you replaced the key fob batteries. Did you per chance use Duracell batteries. If so remove them and check carefully for a child proof coating that is applied to make them taste bad. If the coating exists use something like emery cloth to make sure it is removed.
TBC787
3G RLX Problems & Fixes
Nov 17, 2017 03:42 PM
Ephi82
4G TL Problems & Fixes
Sep 11, 2016 09:08 AM
Dan_Jackson550
1G TL Problems & Fixes
Feb 4, 2010 09:30 AM
bubinga
Jan 12, 2006 10:45 PM
jalpa88
1G TL (1996-1998)
Jun 18, 2005 04:02 AM
